I picked up an '83 280ZX non turbo for my nephew. Is the injector wiring color code the same as on an '82? Also, are the turbo injectors the ones with the little nipple on the end of the injector? I'm trying to find out if these injectors are from a turbo or non turbo. Thanks for any info you can give me...
This just a bump to 'refresh' the thread. Please, someone help me out on this. It seems a pretty simple question to me. I got a service manual but the wiring schematic only goes to 1982, even though it's supposed to be through 1983. That's why the question...
I am not sure why you need the color code for injectors, they are non polarized(they will fir even with reversed polarity) As to finding out what the enjectors were made for, the numbers on them are the best way to find out-check google for the flow rates on the injector numbers you have-that will enable you to find out where they belong.
Will
This is a non running car. The injector rail was not installed. I need to know the color code so I can wire up the injectors. You know, pulse wire set #1 to injector #1, etc, etc. Thanks for the response.
