Posted October 16, 200519 yr comment_141966 Can I run a walbro 255 pump on a stock system, as a improvement on fuel delivery????? Link to comment https://www.classiczcars.com/forums/topic/17648-fuel-pump-question/ Share on other sites More sharing options...
October 16, 200519 yr comment_141971 No, it is an in tank pump, no way to install it in a Z, at least not in a 240. Link to comment https://www.classiczcars.com/forums/topic/17648-fuel-pump-question/#findComment-141971 Share on other sites More sharing options...
October 16, 200519 yr comment_141981 I'm curious, why create 3 threads to ask one question?http://www.classiczcars.com/forums/showthread.php?p=148352#post148352http://www.classiczcars.com/forums/showthread.php?p=148353#post148353http://www.classiczcars.com/forums/showthread.php?p=148359#post148359 Link to comment https://www.classiczcars.com/forums/topic/17648-fuel-pump-question/#findComment-141981 Share on other sites More sharing options...
October 16, 200519 yr comment_141983 I guess he wanted to make sure we all saw it. Each is in a different forum. Link to comment https://www.classiczcars.com/forums/topic/17648-fuel-pump-question/#findComment-141983 Share on other sites More sharing options...
October 16, 200519 yr Author comment_141984 I thought you could get the pump in external as well? Link to comment https://www.classiczcars.com/forums/topic/17648-fuel-pump-question/#findComment-141984 Share on other sites More sharing options...
October 16, 200519 yr comment_141985 I guess he wanted to make sure we all saw it. Each is in a different forum.that is considered SPAMMING Link to comment https://www.classiczcars.com/forums/topic/17648-fuel-pump-question/#findComment-141985 Share on other sites More sharing options...
October 16, 200519 yr Author comment_141987 NO!............ its called getting as many different opinions of different individuals who's may frequent other specific forums.come on guy's....lets not create a subforum over something so trivial.Dont read it, and reply.. if it bothers you. Link to comment https://www.classiczcars.com/forums/topic/17648-fuel-pump-question/#findComment-141987 Share on other sites More sharing options...
October 16, 200519 yr comment_141998 I thought you could get the pump in external as well?My google search showed me an internal I was going on that. If you can get an external it should be fine, just remember 3-5 PSI for carbs max, not sure about EFI but it's a lot more pressure and will flood carbs. Link to comment https://www.classiczcars.com/forums/topic/17648-fuel-pump-question/#findComment-141998 Share on other sites More sharing options...
October 16, 200519 yr comment_141999 No, it's spamming. Normally, if the moderators saw this they would delete all but one thread. Tell me, how many different opinions did you get? Link to comment https://www.classiczcars.com/forums/topic/17648-fuel-pump-question/#findComment-141999 Share on other sites More sharing options...
October 16, 200519 yr comment_142001 OK,I think you have made your point, guy has 20 posts, give him a break, give me a break... If he ever posts again I'm sure after this he won't start more than one thread... Link to comment https://www.classiczcars.com/forums/topic/17648-fuel-pump-question/#findComment-142001 Share on other sites More sharing options...
October 16, 200519 yr comment_142007 Lance: If you had made an effort to educate him, no one else would have needed to. Since you didn't, I did. That shouldn't be a problem for either you or =Enima= had all of the threads been in one forum (posted 1 minute apart) nothing would have been said. It would have been obvious that an error had occured somehow. ps which leg do you want broken? (it's a joke so chill, OK?) Link to comment https://www.classiczcars.com/forums/topic/17648-fuel-pump-question/#findComment-142007 Share on other sites More sharing options...
October 16, 200519 yr comment_142009 Lance: If you had made an effort to educate him, no one else would have needed to. Since you didn't, I did. That shouldn't be a problem for either you or =Enima=had all of the threads been in one forum (posted 1 minute apart) nothing would have been said. It would have been obvious that an error had occured somehow. ps which leg do you want broken? (it's a joke so chill, OK?) OHH fight fight! 20 bucks on Lance! (my real name too!) Link to comment https://www.classiczcars.com/forums/topic/17648-fuel-pump-question/#findComment-142009 Share on other sites More sharing options...
