Is becuase the deck high with the L28 crank and the L16 rods is perfect! to fit into an L24 engine and increase displacement from
stock L24 - 2393
L24 with L28 crank L16 rods L24 pistons HKS 1mm Head gasket - 2565
compression L24 E88 head - 8.76 : 1
with above - 9.28:1
hows that?
The calculator should be in the downloads section. That's where I got it from anyway. Lot of fun to play with when there's nuttin' else to do.:P
BTW, I wouldn't think the 4 cylinder L series rods would be anywhere near strong enough to put in the L-24 thru L-28. Not only that but you would run into piston problems. Not sure if the wrist pin is the same on all L series or not.
Hi guys in reading your posts, the L-16 and the L-24 rods are one in the same. Datsun went to bigger rod cap bolts on them in 72.So the program has a flaw in it.The SSS L-16 is an L-24 with two cylinders cut off.The L-18 and L-26/L-28 rods are the same.
What I never understood is, why did Datsun make the L-26 with a 240 bore and an L-28 stroke when they could have made one with an L-28 bore and L-24 stroke.I'd kinda be like a 302 chevy or ford. 240 Al
what is actually involved in over-boring an engine?
Im not talkin bout just throwin stuff in, im trying to work stuff out, see what i can do to increase the power of the engine, and i like the fact that it probably hasn't been done the L28 crank and rods in the L24.
Matt
if you have the calculator check this out....
L24 block
Ld28 crank
L28 rod
L28 flat pistons
E31 head
this leaves the deck height at 2.030mm
add a 2mm head gasket, your at .030 mm ( calculator doesn't figure for head gasket deck height )
check out the compression and displacment...i know 11.5 is high
now, flip the head to an E88...and fly cut the pistons .5
still 2.7Litre's displacment, but now the compression is at a workable 10.41 : 1 =)
what do you think?
Matt
