Email logins are now active ×
Restoration Spreadsheet(s)
webdawg1
Here's another spreadsheet I currently have done that can be posted for general use by all concerned....
Remember to make any changes to the spreadsheet(s) based on your model year (I.E. - 240, 260, 280) as there will be "some" differences between model years...but for the most part should be pretty accurate...
webdawg1
Fiche 130-1 Dash Side Trim & Glove Box (From Aug 73 ).xls
  • 3 weeks later...
webdawg1
Fiche 96-1 (Brake Piping From Jul '72).xls
webdawg1
Fiche 143A-1 Tail Gate Panel, Trim, Lock & Rear Bumper (From Aug '74 To Jul '76).xls
Remember to make any changes to the spreadsheet(s) based on your model year (I.E. - 240, 260, 280) as there will be "some" differences between model years...but for the most part should be pretty accurate...It also helps if you have the Z Microfiche CD-Rom so you'll know what to change in the various spreadsheets for your model year...
webdawg1
Fiche 89-1 (Front Axle).xls
webdawg1
Fiche 126-1 Front Fender, Hood Ledge, Hood (From Aug '73).xls
webdawg1
Fiche 24-1 Front Cover & Compressor Mounting (From Dec '74).xls
Here's some more spreadsheets I currently have done that can be posted for general use by all concerned....
webdawg1
Fiche 144-1 Seat & Slide (From Aug '73).xls
Fiche 51A-1 Distributor Full TR. Type (From Dec '74).xls
Here's another spreadsheet I currently have done that can be posted for general use by all concerned....according to my list I posted it, but I don't see it anywhere in the posts...
webdawg1
Fiche 99-1 (Master Vac & Vac Hose).xls
Here's some more spreadsheets I currently have done that can be posted for general use by all concerned....Remember to make any changes to the spreadsheet(s) based on your model year (I.E. - 240, 260, 280) as there will be "some" differences between model years...but for the most part should be pretty accurate...It also helps if you have the Z Microfiche CD-Rom so you'll know what to change in the various spreadsheets for your model year...
webdawg1
Fiche 141-1 Door Lock, Window Regulator, Door Handle (From Aug 73 two Seater).xls
Fiche 142-1 Door Moulding Finisher, Arm Rest, Door Mirror (From Aug 73).xls
webdawg1
Fiche 61-1 (Windshield Wiper Motor & Wiper Blade).xls
Fiche 63-1 (Head Lamp).xls
webdawg1
Fiche 43-1 Radiator L28E (From Dec '74).xls
Fiche 62-1 (Windshield Washer).xls
Fiche 64B-1 Front Combination Lamp (From Sept '74).xls
  • Who's Online   1 Member, 0 Anonymous, 261 Guests (See full list)
