I tried it in the calculator and got to 8.9 with an E-31 and dished pistons with a 1 mm head gasket. Could go a bit over 9 if you had to deck the head 10 thousandths to true it.
I think the easiest bet will be the flat tops. Ought to be able to run 91 octane without too much trouble if you keep it close to 10:1. Most of the new cars on the road now are running near to 10:1, but with the old engines without the benefit of the new computer systems running the ignition, injection etc. I think I'd go to 93 octane if possible.
There is always the idea of using a custom piston (pricey) with a lower pin height or a higher dome.
https://www.classiczcars.com/forums/topic/1769-cr-questions/#findComment-7835
"Most of the new cars on the road now are running near to 10:1, "
I couldn't believe that! I saw a write-up of Q45 engines on Freshalloy.com and the street version is 10.something :1!!!!!!! I couldn't believe it. So I would assume with a 6A or a HI6 a 10+:1 L6 would run better on 91.
steve77
https://www.classiczcars.com/forums/topic/1769-cr-questions/#findComment-7852
