Posted October 21, 200519 yr comment_142580 I manage to figure at my last issue and now I am getting spark to the coil,car still wont start ,I don't seem to get power to the fuel pump(tested it with a test lamp)I jump the fuel pump and it started for a bit.What and where do I start in tracing the wire's from the fuel pump?Check all the fuses(good),check the ig relay work's,what is left? Link to comment https://www.classiczcars.com/forums/topic/17691-260z-fuel-inj-fuel/ Share on other sites More sharing options...
