Email logins are now active ×
Plugging the air pump connection on the air cleaner ?
jmark
I just put a piece of tape on mine. I drove with that connection unplugged for years (a previous owner had removed the pump) before realizing that the place where it enters the air box bypasses the air filter. A rubber plug of some sort does seem like a better idea.
I have a weird situation on my 240Z. The air compressor interfers with the part of the air cleaner which hangs down for the air pump. May have to leave it as is or put separate K & N's......I wonder if an early air cleaner w/o the flapper would clear my air compressor.
aside from hi-jacking the therad. The thread is about the air PUMP . Not a air conditioner pump . No the regular air cleaner will not clear . The down side of the seperate filters is not running the tuned volicity stacks that are mounted on the factory air cleaner . You will loose a little power . Gary
Do you think the early non flapper air cleaner will clear?
