Posted October 28, 200519 yr comment_143481 I know this is a dumb question, some people probably say weatherstripping is a fairly self explanatory process. But I just want to make sure I'm doing things right. Does anyone know or have any tutorials on replacing each/most of the weatherstripping on a 240Z? Link to comment https://www.classiczcars.com/forums/topic/17779-weatherstrip-tutorials/ Share on other sites More sharing options...
October 28, 200519 yr comment_143483 I don't but I just did all of mine. What is your question ? Gary :classic: Link to comment https://www.classiczcars.com/forums/topic/17779-weatherstrip-tutorials/#findComment-143483 Share on other sites More sharing options...
October 28, 200519 yr Author comment_143484 ooh yay! =D a) How do I take off the rear hatch glass? How do the Door Cap seals go on? c)The aftermarket lower door seal from Precision seems to have holes in it. I was guessing it was for screwing it on, but the factory seal that's still on the door doesn't have screws. How should I put this one on? Thanks for your time, Gary. Link to comment https://www.classiczcars.com/forums/topic/17779-weatherstrip-tutorials/#findComment-143484 Share on other sites More sharing options...
October 28, 200519 yr comment_143485 There are plastic clips that go through the holes in the w/s, and into corresponding holes in the bottom of the door. you may need to look more carefully to see them, but they are there. Link to comment https://www.classiczcars.com/forums/topic/17779-weatherstrip-tutorials/#findComment-143485 Share on other sites More sharing options...
October 28, 200519 yr comment_143490 I strongly advise that you buy the book How to restore your Datsun Z-car by Wick Humble it is a Fisher Book . All this is covered and shown in the book . Gary Link to comment https://www.classiczcars.com/forums/topic/17779-weatherstrip-tutorials/#findComment-143490 Share on other sites More sharing options...
October 28, 200519 yr comment_143547 ooh yay! =Da) How do I take off the rear hatch glass? How do the Door Cap seals go on? c)The aftermarket lower door seal from Precision seems to have holes in it. I was guessing it was for screwing it on, but the factory seal that's still on the door doesn't have screws. How should I put this one on? Thanks for your time, Gary. To remove hatch glass take a razor and cut the lip of the gasket almost all the lip, then u can push the glass out Link to comment https://www.classiczcars.com/forums/topic/17779-weatherstrip-tutorials/#findComment-143547 Share on other sites More sharing options...
