Brake Line (Metric Steel Tube Nuts)
webdawg1
Was talking with FMSI (FMSIinc.com) today regarding some 3/16" brake line steel tube nuts (Item #3043 3/16" 10mm x 1.0 Japanese) . They said they only sold to jobbers and parts stores and in bulk. They did however turn me on to the "Only" distributor for FMSI in the USA. Guys name is Kevin at (814) 362-3221. Owns 3-4 parts stores (Autopartmart is the name I think) I talked with him for a little bit and he stated that you could order whatever quantity you want. (I.E. - No bulk order requirements) So if anyone wants to make up their own brake lines here's a source for the tube nuts...
webdawg1
No, it's a 3/16" brake line with a 10 x 1 mm nut. The metric brake tube size is damn near identical, its something like 4.7mm IIRC. The 3/16" fitting will work on your stock brake lines just fine.
FWIW I've never had trouble getting a hold of them, and if you can't buy them separately for some reason you can always just buy a 6" length of brake line that is pre-flared and has 2 of them on it already then you don't have to special order anything. I've never been to an autoparts store that didn't have a pre-made line with them already on it in CA or WA, although there was a guy in TX complaining that he had to order the fittings recently on hybridz.
I've bought pre-made lines also, but the fittings always require a US Standard 7/16" wrench, not the Datsun standard 10mm wrench. I hatre having to use a "special wrench" for one line that is different frojm all the others. Wish it was possible to get fittings with the 10mm hex & 10mm x 1.0 thread.
