Posted October 31, 200519 yr comment_143870 Originally I had to manually park the wipers, but now I can't get them to shut off. Thinking it might be related to the infamous "slow wipers" problem, I pulled everything off the car and cleaned & re-lubed the arms to where they are working nicely.I didn't pull the motor apart, just cleaned the exterior up. Plugged the motor back in, and still won't shut off. Could it be the switch on the steering column? If so, any tips on what to look for?Thanks...Robert Link to comment https://www.classiczcars.com/forums/topic/17819-wipers-wont-shut-off/ Share on other sites More sharing options...
October 31, 200519 yr comment_143875 Red Eye:Which car?The 71 does have a mid-cycle park feature which has a couple of wires attached to the back of the wiper motor crank-case. If one of those wires is disconnected or not making proper connection due to a break etc. it will keep cycling as it never gets to the "park" position.The 74 has an intermittent wipe feature, as such it could be the intermittent relay that is either shorted or ....?I'll leave the 83 to Stephen Blake.The 1600's were very similar to the 71.Enrique Link to comment https://www.classiczcars.com/forums/topic/17819-wipers-wont-shut-off/#findComment-143875 Share on other sites More sharing options...
October 31, 200519 yr Author comment_143895 Sorry, it's on the '71...Robert Link to comment https://www.classiczcars.com/forums/topic/17819-wipers-wont-shut-off/#findComment-143895 Share on other sites More sharing options...
October 31, 200519 yr comment_143901 No worries, but did the answer I mentioned help you?E Link to comment https://www.classiczcars.com/forums/topic/17819-wipers-wont-shut-off/#findComment-143901 Share on other sites More sharing options...
October 31, 200519 yr Author comment_143909 I'll check it out when I get home, thanks for your help Link to comment https://www.classiczcars.com/forums/topic/17819-wipers-wont-shut-off/#findComment-143909 Share on other sites More sharing options...
November 1, 200519 yr Author comment_143995 EScanlon said: Red Eye:The 71 does have a mid-cycle park feature which has a couple of wires attached to the back of the wiper motor crank-case. If one of those wires is disconnected or not making proper connection due to a break etc. it will keep cycling as it never gets to the "park" position. Enrique I guess I don't know what you mean by crank-case. Link to comment https://www.classiczcars.com/forums/topic/17819-wipers-wont-shut-off/#findComment-143995 Share on other sites More sharing options...
November 1, 200519 yr comment_144006 Ok, here goes. Hopefully my pic editing worked. E Link to comment https://www.classiczcars.com/forums/topic/17819-wipers-wont-shut-off/#findComment-144006 Share on other sites More sharing options...
November 1, 200519 yr Author comment_144017 Wow, thanks alot...Robert Link to comment https://www.classiczcars.com/forums/topic/17819-wipers-wont-shut-off/#findComment-144017 Share on other sites More sharing options...
November 2, 200519 yr Author comment_144201 Well, the wires seem OK, at least from visual inspection. I loosened the screws and moved the Park Position Switch around some, but the wipers still wouldn't shut off. I'm wondering if the metal tang on the inside of the Park Switch isn't making contact??? Link to comment https://www.classiczcars.com/forums/topic/17819-wipers-wont-shut-off/#findComment-144201 Share on other sites More sharing options...
November 3, 200519 yr comment_144278 Do a continuity check to ensure that the wires aren't broken someplace along their length. As far as the park switch, that "bump" is supposed to lift the reed and break the circuit. Is the nylon pad worn out? After this, the only thing I can imagine that may cause the problem is a down-right short circuit in the switch itself. See the following pic. Hope it helps. Enrique Link to comment https://www.classiczcars.com/forums/topic/17819-wipers-wont-shut-off/#findComment-144278 Share on other sites More sharing options...
