Posted October 31, 200519 yr comment_143876 I was in the middle of removing my rack and pinion for a little refreshing of my steering rack (fresh grease, new seal, new boots, new tierod ends) when I found out why it is suggested that you remove or lift the engine up a couple of inches to remove the rack and pinion. While pulling the assembly out, that dirty, greasy knob thing broke off!! I've checked VB and MSA's catalogs and they don't carry this piece. Should I replace it with OEM (don't you just hate going to the Nissan dealers??) or is there some way to eliminate the reservoir altogether? (i.e. remove and plug hole or maybe install zerk fitting into hole to grease that end of the tube??) If the OEM reservoir is the best solution, who other than Nissan would carry one?Kinda looking for suggestions from anyone who has done this before. Link to comment https://www.classiczcars.com/forums/topic/17820-steering-rack-grease-reservoir-made-of-plastic/ Share on other sites More sharing options...
October 31, 200519 yr comment_143911 I remember reading about this in an earlier post. Couldn't find the exact one. This one has the part # and a picture. If I remember correctly they are NLA.http://www.classiczcars.com/forums/showthread.php?t=9936&highlight=steering+rack+reservoir Link to comment https://www.classiczcars.com/forums/topic/17820-steering-rack-grease-reservoir-made-of-plastic/#findComment-143911 Share on other sites More sharing options...
November 1, 200519 yr Author comment_143916 Thanks for the info, it was just what I was looking for! I thought that a zerk fitting might be my best option, now I just have to figure out which size fitting to use. Off the top of your head, do you know what size hole that is?? Link to comment https://www.classiczcars.com/forums/topic/17820-steering-rack-grease-reservoir-made-of-plastic/#findComment-143916 Share on other sites More sharing options...
