Posted November 1, 200519 yr comment_143983 I hav noticed that one of the SU carbs on my 1970 240Z is low on the oil that goes in the top. Every book I have read says you MUST put SAE 20 oil in there. I can't find that at any local auto store. Is there an alternative or where would I find SAE20 oil? I also cant tell exactly where the fill line is. What is the proper level in the carb?Thanks........ Link to comment https://www.classiczcars.com/forums/topic/17828-su-carb-oil-sae20/ Share on other sites More sharing options...
November 1, 200519 yr comment_143985 Well, you could order it from MSA. I also found 20 weight oil at Ace Hardware. I think it was sold under the 3 in 1 brand. Link to comment https://www.classiczcars.com/forums/topic/17828-su-carb-oil-sae20/#findComment-143985 Share on other sites More sharing options...
November 1, 200519 yr comment_143997 I found some at the local parts store, apparently new Hondas are using it. 0w-20. It was kinda expensive because it's synthetic. I went back to 30wt since it's getting cold, my acceleration seems a little better now. Link to comment https://www.classiczcars.com/forums/topic/17828-su-carb-oil-sae20/#findComment-143997 Share on other sites More sharing options...
November 1, 200519 yr comment_144005 0w-20 is a multiweight oil. It would not necessarily act like 20 weight oil all of the time. I'm not sure how a thicker oil would help you when it gets colder. It sounds counter-intuitive to me. Link to comment https://www.classiczcars.com/forums/topic/17828-su-carb-oil-sae20/#findComment-144005 Share on other sites More sharing options...
November 1, 200519 yr comment_144009 Should be able to get straight 20 weight at a motorcycle shop - most brands of fork oil are available in that weight. Link to comment https://www.classiczcars.com/forums/topic/17828-su-carb-oil-sae20/#findComment-144009 Share on other sites More sharing options...
November 2, 200519 yr comment_144084 A good quality of ATF is recommended by "ZTherapy". It just happened to be what I had been using for some time. It is great, but a bit thinner so check it every so often.Hope that helps-72 240 Link to comment https://www.classiczcars.com/forums/topic/17828-su-carb-oil-sae20/#findComment-144084 Share on other sites More sharing options...
November 2, 200519 yr Author comment_144124 Sorry but what is ATF? Link to comment https://www.classiczcars.com/forums/topic/17828-su-carb-oil-sae20/#findComment-144124 Share on other sites More sharing options...
November 2, 200519 yr comment_144132 Automatic Transmission Fluid Link to comment https://www.classiczcars.com/forums/topic/17828-su-carb-oil-sae20/#findComment-144132 Share on other sites More sharing options...
November 8, 200519 yr comment_145027 ddezso said: Sorry but what is ATF? Spoken like a true lover of driving......ATF what? . Link to comment https://www.classiczcars.com/forums/topic/17828-su-carb-oil-sae20/#findComment-145027 Share on other sites More sharing options...
November 8, 200519 yr comment_145042 I'd previously been recommended (and used) sewing machine oil. I'm now using a machine oil - engine oil mixture and it's eleventy billion time better. Nice sharp throttle response. Now...I just can't remember the damn ratio! Link to comment https://www.classiczcars.com/forums/topic/17828-su-carb-oil-sae20/#findComment-145042 Share on other sites More sharing options...
November 8, 200519 yr comment_145087 Most Automatic Transmission Fluid is 20wt oil. And several people use it in the carbs. I do and have no problems. The fill line is on the shaft. Don't worry if you over fill. It will get sucked into the engine and burn off. Link to comment https://www.classiczcars.com/forums/topic/17828-su-carb-oil-sae20/#findComment-145087 Share on other sites More sharing options...
November 8, 200519 yr comment_145114 Ed, I think you can safely say most people. Link to comment https://www.classiczcars.com/forums/topic/17828-su-carb-oil-sae20/#findComment-145114 Share on other sites More sharing options...
