78 280Z CAR,
your air regulator has 2 hoses on it under one of them is the connection if this is loose its probly the problem. Mine would just pull out of the regulator housing. This should be sealed tight on to the regulator. If its loose you probly need a new one. I found a used one it was more cost effective. LOL
Good Luck,
John
The connection is not loose at all. There is voltage going to it. I think it is stuck closed. I took it off and tried it plugged in while it was cold but it would stay closed. Is'nt it suppose to be open while the car is cold?
Also, I drove it home teday and the speedometer said I was going 70 but my mother in law told me I was only going 60. I just did a auto to 5 speed swap do I have the wrong speedo gear and what color gear do I need for the five speed? Thanks, Shane
Yep, that test is originally from my FSM (1977)
Only way I can answer your speedometer question is to know which differential you got? It doesn't matter which year Z trans. you have. (77-83) The speedometer is metered by the cog on the end of the speedo cable that threads into the transmission and is paired with the differential only.
I used the cog that was already in the 5 speed, when I got it from pick and pull I just left the cog in there. It seems to run at a normal speed range when I am driving around in the city. It is just when I am on the freeway that it revs or is at a different speed. I will check the cog that I have in there tomorrow and find out what is going on. Thanks datsunzsrule. Its pretty funny though I thought I was going to fast because of the rebuilt engine I was trying to break in and I was actually going slower.
I Just found out that the engine has a hard time starting at first after it is already hot. :paranoid: .
Shane
There ya go :) you have the wrong cog then. Most r180 3.36 (on 280Z's) were used on Automatic models and you left the cog in the tranny from the donor car which means you have a 17 tooth or possibly a 19 tooth for the 3.9
What 5 speed tranny did you get? 77-80 or 81-83
aahh, hard time starting at first after it is already hot huh? that pretty much tells me right there it's the thermotime switch like mine. Still don't hurt to test it if you want to make sure :)
Glad to help as always
