Since my goal is to have a mostly stock-looking driver, absolute originality isn't crucial. That said, I do want it to look "period" so I will try to find a stock-looking radio of some kind. But I'll be using both speakers in back, probably with a small amp that has an auxiliary input jack for my iPod.
Thanks for all the input guys. Since I am not going to have a frame off showcar but just want a tight, clean refreshed Z car, would one of the later radios like the one you pictured 26th-Z, fit into the slot on a 1970? It looks to have AM and FM and I assume it is stereo......?
That way I still have the period look rather than a blue neon flux capacitor retratactable removable DVD flat screen stereo.
Get the AM/FM with the switch above the tuning knob. It is an "original" model and at least you'll have access to the FM band.
It isn't stereo, and it will fit in the 70-73 dash.
Thanks for the input on the Ohm's.
E
ROFL aint that the truth!
Regarding the speaker wiring (series vs. parallel), the important thing is to have the total speaker load match the rating of the radio power amp output. In addition, the speakers should have a power rating that is the same or higher than the power output of the radio. I'm not sure where to find these tidbits of information, perhaps in the service manual somewhere?
For arguments sake, let's say the radio is designed to operate into a 4 Ohm load. You could hook up one 4 Ohm speaker, two 8 ohm speakers in parallel, or two 2 Ohm speakers in series. All three variations would present the same 4 Ohm load to the radio.
Now let's say the power output of the radio is 20 Watts. If only one speaker is hooked up, it should be rated for 20 Watts or more. If two speakers are hooked up, they should be rated for 10 Watts or more.
When connecting two speakers together in a mono setup, I'd wire them in parallel. That way if one blows, there is still a load on the radio's power amp. Without a load, the power amp section could burn up.
Sorry, this is a little off topic, but does anyone here have 72 or 73 radios? I don't really care if they work or not, just have a decent face plate. Both of my cars are missing the original units and I want em!
  • 4 months later...
Found this while going through some paperwork. Hope it helps others:
Hitachi Car Radio Model KM-1520ZC Operating guide.
Will post more later, but for now:
SPECIFICATIONS:
CIRCUIT SYSTEM: All transistor superheterodyne with RM am. system
TUNING RANGE: FM 88 ~ 108MHz; AM 535 ~ 1,605KHz
TRANSISTOR: 13
IC: 1
DIODE: 9
THERMISTOR: 2
POWER SUPPLY: DC 12V negative ground
CURRENT CONSUMPTION: 200mA (with no signal)
AUDIO OUTPUT: 3.5W (THD 10%)
LOUDSPEAKER: 5 1/8" PM 4 ohms
ANTENNA: Power Antenna (RO-74B)
WEIGHT: 2 lbs 14 oz.
This is from the P7630871 Brochure from Hitachi LTD.
  • 2 years later...
Hi, i know this is a very late reply, i have a 1970 stock hitachi radio. I haven't checked the later interior posts until now. If you're still interested in an org. 1970 radio, shoot me an e-mail, danlinquist@yahoo.com. I hope this helps. Danny
Yes - I'd say that two years and five monts is VERY LATE... understatement of the year perhaps?
just too funny....
Carl B.
just too funny....
Carl B.
And for the record I got a radio from Baddog about 2 years ago.....
