November 8, 200519 yr Author comment_145033 So Mark, what is wrong with the modified stock air cleaner you are now using? Changing to ITG or K&N's isn't going to make much difference over what you have now?If it were me, I'd probably want to rework the A/C so that I could use the stock air box. Every other A/C I've seen on Z's mounted the compressor on the opposite side of the engine.Probably nothing. Just doesn't look that great. I can't see reworking a functioning AC system just for the air cleaner interference. I think air horns with the ITG cleaners would look much nicer. Are these the correct air horns?http://www.twminduction.com/AirHorn/AirHorn-FR.html Link to comment https://www.classiczcars.com/forums/topic/17859-anybody-using-the-dual-itg-air-cleaners/?&page=2#findComment-145033 Share on other sites More sharing options...
November 8, 200519 yr comment_145040 those look like them. However, if you're going to essentially 'toss' your current stock type air cleaner, your best bet is to just cut out the air horns in the stock air filter housing and use those....they can't be seen, and the stock ones are the best designed ones anyways. Link to comment https://www.classiczcars.com/forums/topic/17859-anybody-using-the-dual-itg-air-cleaners/?&page=2#findComment-145040 Share on other sites More sharing options...
January 2, 200619 yr comment_150855 i dig the k&ns as well.... here's my set up (in my dirty engine bay; now they're in the clean one)Hi Jason,I am thinking of going this route soon. Do you have a part number for the K&N's you bought? Where did you get your air horns from? Do you have a part number for those and the cost?TIA,Marty Link to comment https://www.classiczcars.com/forums/topic/17859-anybody-using-the-dual-itg-air-cleaners/?&page=2#findComment-150855 Share on other sites More sharing options...
January 3, 200619 yr comment_150918 marty - i got the entire set up from MSA. they also have them through VB, but here's a link:k&ns: http://www.zcarparts.com/store/merchant.mvc?Screen=CTGY&Category_Code=PFFC10air horns: http://www.zcarparts.com/store/merchant.mvc?Screen=CTGY&Category_Code=PFFC07 Link to comment https://www.classiczcars.com/forums/topic/17859-anybody-using-the-dual-itg-air-cleaners/?&page=2#findComment-150918 Share on other sites More sharing options...
January 4, 200619 yr comment_151049 I would think you would decrease preformance with that setup. You're allowing two big open filters to suck super hot air in from the engine bay (especially with the header right below it). Probably not. I put a few temp sensors in the engine compartment of my 240Z and once you get the car moving about 25 mph there's at most a 7 degree difference between the underhood temps and abient. At idle you will see significant increases in underhood temps but once the car gets moving the Zs engine compartment cools down quickly. Also did similar testing on my 2000 Ford Contour SVT and a racing BMW 325is. All showed very similar results to my 240Z test. Link to comment https://www.classiczcars.com/forums/topic/17859-anybody-using-the-dual-itg-air-cleaners/?&page=2#findComment-151049 Share on other sites More sharing options...
January 4, 200619 yr Author comment_151055 John,Do you have any pics of your set up? Link to comment https://www.classiczcars.com/forums/topic/17859-anybody-using-the-dual-itg-air-cleaners/?&page=2#findComment-151055 Share on other sites More sharing options...
January 4, 200619 yr comment_151056 Not in electronic form. When the car was a street/autocross car I ran individual ITG air filters on the SUs and built an overkill heat shield:http://www.betamotorsports.com/benchracing/heatshield.html Link to comment https://www.classiczcars.com/forums/topic/17859-anybody-using-the-dual-itg-air-cleaners/?&page=2#findComment-151056 Share on other sites More sharing options...
January 4, 200619 yr Author comment_151057 I plan on using the individual ITG air cleaners with the TWM air horns too. Link to comment https://www.classiczcars.com/forums/topic/17859-anybody-using-the-dual-itg-air-cleaners/?&page=2#findComment-151057 Share on other sites More sharing options...
