I need a socket and pigtail for a rear taillight for a 1973 240Z. The plastic has broken. I do not want to buy a whole new harness so I need the socket and wiring for the back taillight only. Does anyone know where I can get this puppy? It is the socket and wire only I don't want the harness. By the way it is for the RIGHT rear taillight. Thanks for the help if you can.
https://www.classiczcars.com/forums/topic/17894-pigtail-and-socket-for-240z/
It might be easy enough to find a single bulb holder and wire to splice into your tail-light wiring harness, but you might be able to get a complete tail-light wire harness easily enough.
You need to specify whether you need the ONE bulb connector, or the Tail-Light Harness (which includes 4 bulb connectors).
E
