Tail gate channel rubber buttons (part #?)
71ZZZZZ
My Z is being stripped to metal, in removing as much small stuff as I could, I had to trash the little rubber buttons that are on either side of the tail gate channels below the hatch bumpers...I can't locate that part in the parts CD diagram of the area...also needing the two rubber plugs on the bottom of the hatch, is this the "grommet" (#71, on page 121 -6)? Thanks for any info...
:beard:
I got a both of these plugs from MSA. Here are the part numbers I found after looking through my receipts:
341153 Rear Deck Plug, 70-78
141141 Plug Deck Outer Side 70-78
I remember that at the time I placed the order, I couldn't find the "button" shaped plugs in the catalog. I asked the guy taking my order, and he knew what I was talking about. Sure enough, they showed up with the rest of the parts I ordered!
