Funny sounds from up front
RossT
I recently bought a 1980 280Z after a few years of driving and restoring lesser vehicles. When I turn full lock there is a clicking/clunking noise from whichever side I am turning towards. I can't find anything wrong with steering components and maybe they all do that but it is a bit unnerving...
Ross Thompson
Dunedin, New Zealand
Check your wheel bearings and also that your tires aren't rubbing at full lock. You may also want to make sure your torsion bar bushings are not slack or worn. Also check your lower control arm bushings, tie rod ends and ball joints.
