Posted November 8, 200519 yr comment_144974 im helping a friend of mine take out his blown(as in ruiined) l28 and replacing it with another what all do i need to disconnect remove b4 i can do this. and where are the best place to attach the engine hoist chains. i have already removed fuel lines and belts radiator line and all the obvious things. do i need to pull it with the tranny still attached??? any input would be apreciated. also anylinks to helpful websites would be great Link to comment https://www.classiczcars.com/forums/topic/17922-engine-removal/ Share on other sites More sharing options...
November 8, 200519 yr comment_144989 see the following post for some suggestions:http://www.classiczcars.com/forums/showthread.php?t=7366&highlight=engine+removalgood luck! Link to comment https://www.classiczcars.com/forums/topic/17922-engine-removal/#findComment-144989 Share on other sites More sharing options...
November 8, 200519 yr comment_144990 I'd also pull the fan, radiator, wiring (starter, oil pressure sending unit, alternator, coolant temp sending unit, distributor, etc...). Be sure to label everything. If you have a digital camera, take lots of pictures, they will help jog your memory! What kind of tranny, auto or manual? Drain it if it's an auto and remove all wiring. If it's a manual disconnect the clutch plumbing. Make sure the shift linkage is disconnect for either one. Drop the drive shaft & pull the engine & tranny togther. Remove the carbs, intake & exhaust manifolds. Not essential, but easier to manouever without them on. If the exhaust manifold is left on, then disconnect the pipe from the manifold.I use a leveling sling. I connected one end to the rear of the head using an exhaust manifold mounting stud. The other end was connected to the front of the head using one of the AC compressor mounting holes & a heavy duty bold. A leveling sling will help you tilt the engine & tranny as you lift them from the car. Link to comment https://www.classiczcars.com/forums/topic/17922-engine-removal/#findComment-144990 Share on other sites More sharing options...
November 8, 200519 yr comment_144991 yeah, definitely remove along with the tranny. I've done it both ways and its actually easier to do this way. Link to comment https://www.classiczcars.com/forums/topic/17922-engine-removal/#findComment-144991 Share on other sites More sharing options...
November 8, 200519 yr comment_144998 I unhooked the radiator and and pulled it, unhooked all wires and hoses. I then disconnected the drive shaft and jacked up the tranny a bit to hold it up and took off the tranny mount. I then took off motor mounts and about 25mins after starting my friend and I had an engine and tranny sitting on the floor. Link to comment https://www.classiczcars.com/forums/topic/17922-engine-removal/#findComment-144998 Share on other sites More sharing options...
November 25, 20186 yr comment_562334 I'm also getting ready to remove the motor in my 71 240z project, I was going to separate the tranny from the engine because I don't have a lot of room in my garage. Will this be okay ? Link to comment https://www.classiczcars.com/forums/topic/17922-engine-removal/#findComment-562334 Share on other sites More sharing options...
November 25, 20186 yr comment_562338 Room for storage or room for maneuvering? There is nothing to hold the transmission up if it's disconnected from the engine. You'll have to rig up some cables or rope and hang it from the hood latch or let it sit on the ground underneath the car, or on blocks under the car. If you want to work on it you'll have to raise the car high enough to slide it out. Those are some reasons that it's actually easier to pull both at once. If you pull both, you can always slide half of the trans back under the car for storage, or stick the starter bolts back in and stand it on end. Takes up about half the space. The bolts are to keep the input shaft off of the ground. Link to comment https://www.classiczcars.com/forums/topic/17922-engine-removal/#findComment-562338 Share on other sites More sharing options...
November 25, 20186 yr comment_562341 What I meant, I'm not sure I have enough length in the garage to maneuver the engine, puller & tranny altogether, but my wife said just open the ...... garage door. Link to comment https://www.classiczcars.com/forums/topic/17922-engine-removal/#findComment-562341 Share on other sites More sharing options...
November 25, 20186 yr comment_562343 On 11/25/2018 at 1:23 AM, BLZ71 said: What I meant, I'm not sure I have enough length in the garage to maneuver the engine, puller & tranny altogether, but my wife said just open the ...... garage door. Yes what she said. Roll the car part way out, then pull the drive train. Rearrange and roll the car back in. Link to comment https://www.classiczcars.com/forums/topic/17922-engine-removal/#findComment-562343 Share on other sites More sharing options...
November 25, 20186 yr comment_562347 Pretty common to lift, move the car, drop the parts and move them, then move the car back. Easier than trying to roll a cherry picker around on its tiny wheels with 500 pounds swinging from it. Link to comment https://www.classiczcars.com/forums/topic/17922-engine-removal/#findComment-562347 Share on other sites More sharing options...
November 25, 20186 yr comment_562349 r Thanks for your help, I will be picking up the cherry picker tomorrow, it looks like it should be pretty straight forward. I hope you guys don't get tired of my post Link to comment https://www.classiczcars.com/forums/topic/17922-engine-removal/#findComment-562349 Share on other sites More sharing options...
November 25, 20186 yr comment_562350 Just before pulling the engine/trans combo, put a jack under the Diff and lift the rear end of the car, makes pulling the engine easier, a shallower angle. We won't get tired as long as you are posting pics Link to comment https://www.classiczcars.com/forums/topic/17922-engine-removal/#findComment-562350 Share on other sites More sharing options...
