Cant keep my ass on the road
71_240Z
What are the rear suspension bushings like? How about the moustache bar? Is the differential mount shot? These are things I'd check in addition to the struts & springs. Even if everything looks ok, you may want to check that all mounting bolts are tightened to spec.
Are you sure about that? Could have sworn they had a 7/8" sway bar back there just like 280's did. Why would you not have one????
Rear sway bar was added as factory equipment in '74, with the 260Z. All 240Z's came with a smaller front bar (than the 260/280s) and none at all in the rear.
The lighter 240Z didn't need the sway bar to handle nice, it was added to try to compensate for the later cars' extra weight.
no sway bar here... do you think adding one would help keep my butt on the road? I have never understood the purpose of adding sway bars - exept for the coolness factor.
I am convinced that I need new struts. Help convince me on the sway bar.
Thanks.
Interesting. Lighter or not, I would have to say it would be a good up grade for your 240Z. http://www.zcarparts.com/store/merchant.mvc?Screen=PROD&Product_Code=23-4101&Category_Code=PSDC05
if your taking fast, hard turns which it sounds like you do :D This (in my opinion) is a damn good upgrade. especially if plan on Auto Xing once in a while.
Will it help your problem? I'd still do an inspection of all your rear end components. Take care of your shocks first if those are shot and make sure every nut and bolt is torqued down to factory specs. I'm sure you have done this already but have you checked the wheel lug nut torque? Some rims require being torqued down more than once when it's been completely removed.Just another thought :)
But anyways yes, I would highly recommend putting the sway bars on. We drive a lot faster on our roadways now compared to back in the early 70's :)
Good luck.
I agree with Arne. Put some new struts on first...then get some springs and sway bars.
For me, adding stiffer springs and aftermarket sway bars was the best upgrade I've made to my 1973 240Z. I went with Suspension Techniques Sport Springs and sway bars.
After the installation, my car corners flatter and handles more neutrally (I love the occasional four wheel drift on freeway onramps :D). The car also sits lower with the aftermarket springs and has a nice stance.
Cheers,
Sean
I guess I forgot to say that I also agree with DatsunZsRule :o . That's what I get for not completely reading all of the posts in a thread before replying.
DatsunZsRule,
I see you're in Minnesota. Snow yet? Already put your Z away from the winter? Perhaps you're a little touchy due to Z withdrawl? :cheeky:
Cheers,
  • Who's Online   1 Member, 1 Anonymous, 584 Guests (See full list)
