Posted November 8, 200519 yr comment_145145 Hi all,I was just looking through the online ARP catalog and found that they don't carry Datsun specific bolts for flywheel and pressure plate. They do however have a selection of these bolts for both Honda and Toyota metric applications.So does someone happen to know if our flywheel bolts are M10x1.0 or M12x1.25?Same question for the pressure plate.Thanks,-e Link to comment https://www.classiczcars.com/forums/topic/17937-arp-flywheelclutch-bolts/ Share on other sites More sharing options...
November 13, 200519 yr comment_145783 The flywheel bolts are 12 x 1.25 and are 27mm long they also have an oversized head requiring a 19mm socket.The pressure plate bolts are 8 x 1.25 not sure about the length but somewhere around 19mm. Link to comment https://www.classiczcars.com/forums/topic/17937-arp-flywheelclutch-bolts/#findComment-145783 Share on other sites More sharing options...
November 15, 200519 yr comment_145996 you NEED to get Grade 8 (metric) or 10.9 (sae) for those bolts.. dont go any lower Link to comment https://www.classiczcars.com/forums/topic/17937-arp-flywheelclutch-bolts/#findComment-145996 Share on other sites More sharing options...
November 15, 200519 yr comment_146000 actually, it would be Grade 10.9 for metric bolts; or Grade 8 for SAE bolts Link to comment https://www.classiczcars.com/forums/topic/17937-arp-flywheelclutch-bolts/#findComment-146000 Share on other sites More sharing options...
