Posted November 9, 200519 yr comment_145326 Hi Guys, I have a basically stock 75' 280Z and I was just wondering what I could put in to get a little more power off the line from my L28. The only things I have done to the car is heavy gauge wires, new plugs, and a K&N Cold air induction system. If you have any suggestions they would be greatly appreciated. Jason Link to comment https://www.classiczcars.com/forums/topic/17956-power/ Share on other sites More sharing options...
November 9, 200519 yr comment_145329 Just the normal hot rod stuff. Here's a site with good info, but don't consider it to be the absolute last word. Should give you some ideas, though.http://www.geocities.com/zgarage2001/engine.html Link to comment https://www.classiczcars.com/forums/topic/17956-power/#findComment-145329 Share on other sites More sharing options...
November 14, 200519 yr comment_145945 First and foremost I would say the best thing that you could do to get a little more off the line, is basically fine tune your car. Properly adjust your valves, run a hotter set of plugs, with properly adjusted gap. Better coil, good wires, clean fuel filter, a good cap and rotor with brass inserts is always better. Make sure shes in good tune basically, that is the first and best upgrade you can do. Link to comment https://www.classiczcars.com/forums/topic/17956-power/#findComment-145945 Share on other sites More sharing options...
November 14, 200519 yr comment_145958 lower gearing in the diff. Link to comment https://www.classiczcars.com/forums/topic/17956-power/#findComment-145958 Share on other sites More sharing options...
