Email logins are now active ×
Power
Spieg16
Hi Guys,
I have a basically stock 75' 280Z and I was just wondering what I could put in to get a little more power off the line from my L28. The only things I have done to the car is heavy gauge wires, new plugs, and a K&N Cold air induction system. If you have any suggestions they would be greatly appreciated.
Jason
First and foremost I would say the best thing that you could do to get a little more off the line, is basically fine tune your car. Properly adjust your valves, run a hotter set of plugs, with properly adjusted gap. Better coil, good wires, clean fuel filter, a good cap and rotor with brass inserts is always better.
Make sure shes in good tune basically, that is the first and best upgrade you can do.
