hey all... question.
does anyone know where on the ignition switch the green wire from teh voltage regulator goes? to be more specific...the "green" wire comes off the VR plug and according to the wiring diagrams i have it goes directly to the ignition switch. if only that were so... it goes thru a punch of connection points first.
was wondering if this wire is supposed to be connected in a splice to the black with a blue stripe at the switch. if not, can i connect it there anyway to get power? there is a constant power send once teh switch is on at the black/blue wire.
https://www.classiczcars.com/forums/topic/17970-green-wire/
My question to you is what diagram are you using? If this is for your '75, the green wire goes to the tach (and several other places), but not the ignition switch.
Attached is a pdf of the with the green wire you are referring to highlighted (in green).
EDIT: this file opens w/ Adobe Reader 7.0.
Wayne
75-green.pdf
