Posted November 13, 200519 yr comment_145774 There are probably a bunch of these out there already but I worked this one out to answer some of my own questions. Should be easy enough to modify if you are using different transmission ratios or want to try a different rear end ratio, just plug in the numbers. Enter in the revs per mile for the tire you are using and the rest is figured. I got the revs info from the data provided at tirerack.com for the tires I am interested in using. The trans ratios I got from zgarage.com. I may have screwed up big time with the caculations but the numbers look right, if you find I made a mistake let me know and I'll fix it Edit: OK, latest and greatest posted, added some shift point data. I really need to get to work on something important Z gear ratios.xls Link to comment https://www.classiczcars.com/forums/topic/18000-tire-sizegear-ratiotransrpmmph-spreadsheet/ Share on other sites More sharing options...
November 13, 200519 yr comment_145775 Looks pretty nice. Nothing for poor automatics like myself. Link to comment https://www.classiczcars.com/forums/topic/18000-tire-sizegear-ratiotransrpmmph-spreadsheet/#findComment-145775 Share on other sites More sharing options...
November 13, 200519 yr Author comment_145778 Any idea what the ratios are for an auto? Just plug in the ratios for 1,2,3rd gears on any of the lines and you should have your answers Link to comment https://www.classiczcars.com/forums/topic/18000-tire-sizegear-ratiotransrpmmph-spreadsheet/#findComment-145778 Share on other sites More sharing options...
November 13, 200519 yr comment_145781 Any idea what the ratios are for an auto? Just plug in the ratios for 1,2,3rd gears on any of the lines and you should have your answers D'oh, you're totally right. That's what I get for acting before thinking. I'll have to dig up the owners manual and plug in the numbers. Link to comment https://www.classiczcars.com/forums/topic/18000-tire-sizegear-ratiotransrpmmph-spreadsheet/#findComment-145781 Share on other sites More sharing options...
November 13, 200519 yr comment_145786 Edit:Found an error in the first file, use the second one that is 25 KB in size. Don't know how to delete the first one....go to the "edit post" page, click "manage attachments" when that window opens there should be a "remove" option next to each existing file attached. click the one you want to go away. SAVE CHANGES, Bam, done Link to comment https://www.classiczcars.com/forums/topic/18000-tire-sizegear-ratiotransrpmmph-spreadsheet/#findComment-145786 Share on other sites More sharing options...
November 13, 200519 yr Author comment_145787 go to the "edit post" page, click "manage attachments" when that window opens there should be a "remove" option next to each existing file attached. click the one you want to go away. SAVE CHANGES, Bam, done Thank you very much, a blind man could see the REMOVE button, I must be really blind Latest version posted... Thanks again montoya_fan01 Link to comment https://www.classiczcars.com/forums/topic/18000-tire-sizegear-ratiotransrpmmph-spreadsheet/#findComment-145787 Share on other sites More sharing options...
