Do you still have the ABV in place still? (anti-backfire valve) It allows fresh air into the system to prevent the backfires- when i put SU's on my 260, i removed mine, and get minor backfires whenever i decelerate, or use the engine to brake.
I try to think of it as the Z "burping" after chewing up some road:cool:
Jeremiah
The timing being off a little could also contribute to the backfiring. If you haven't done it yet, a complete tune-up would be a good place to start. Plugs, points, condensor, timing check, check your plug wires, cap and rotor. If this fails then go for the carb adjustments, and check the ABV.
