Fuel strainer
mriz
I've got the vise grips on the line and will pull the top off the pump tonight but is there anything inside the pump to be concerned about(parts falling out) . P.S read all your other F.I. posts and will go after air regulator, bccd and altitude switch next (high idle) just figured on doing strainer while suspension is out.
  • 3 months later...
