Posted November 15, 200519 yr comment_146022 ok, soo...do i need to replace these or can i use like berrymans or something to "adjust" these into nice non making sounds working order? i have no clue if i just made any sense...but a buddy pointed out a sound which is one of my lifters out of adjustment or something-- Link to comment https://www.classiczcars.com/forums/topic/18024-lifters-or-rings/ Share on other sites More sharing options...
November 15, 200519 yr comment_146050 If you have an overly noisy lifter (rocker), adjust it. No chemical is going to quiet it down. Go through an adjust the valve lash on all of them. Keep in mind that a little noise is good. A little loose is better than too tight. Link to comment https://www.classiczcars.com/forums/topic/18024-lifters-or-rings/#findComment-146050 Share on other sites More sharing options...
November 23, 200519 yr Author comment_146989 ok, 2nd question is.. whast with the guys in the movies listening to engines with a stethescope? Link to comment https://www.classiczcars.com/forums/topic/18024-lifters-or-rings/#findComment-146989 Share on other sites More sharing options...
November 23, 200519 yr comment_147014 Yah J Z, I just put my ear to the end of a long screwdriver. Stethescopes are just for guys with too much money (doctors?). Link to comment https://www.classiczcars.com/forums/topic/18024-lifters-or-rings/#findComment-147014 Share on other sites More sharing options...
November 23, 200519 yr Author comment_147053 well, what are you guys listening for? Link to comment https://www.classiczcars.com/forums/topic/18024-lifters-or-rings/#findComment-147053 Share on other sites More sharing options...
November 23, 200519 yr comment_147059 well, what are you guys listening for?It makes it easier to find bad bearings. Link to comment https://www.classiczcars.com/forums/topic/18024-lifters-or-rings/#findComment-147059 Share on other sites More sharing options...
November 23, 200519 yr comment_147064 Yah J Z, I just put my ear to the end of a long screwdriver. Stethescopes are just for guys with too much money (doctors?). I have a mehcanic's stethoscope and I doubt if anyone would ever accuse me of having too much money. They are invaluable when it comes to listening to fuel injectors. You can hear the sound of them opening and closing, or if they're not. Also, with a stethoscope, rather than a screwdriver, you can discern weak vs. normal sounds like a clogged injector which won't sound as loud as a properly operating injector. Link to comment https://www.classiczcars.com/forums/topic/18024-lifters-or-rings/#findComment-147064 Share on other sites More sharing options...
