Posted November 16, 200519 yr comment_146222 Just bought a set of 17" x 7"with the correct 4" backspace centerline wheels for my stock ride height 73 240z what tire size fits best? I've think 205/45/17 or is it 205/40/17 ? any help would be appreciated thanks. Link to comment https://www.classiczcars.com/forums/topic/18046-centerline-17-wheels/ Share on other sites More sharing options...
November 16, 200519 yr comment_146234 tire size calculator is always helpfulhttp://www.1010tires.com/TireSizeCalculator.aspcd Link to comment https://www.classiczcars.com/forums/topic/18046-centerline-17-wheels/#findComment-146234 Share on other sites More sharing options...
November 16, 200519 yr comment_146238 Depends on what effect you are looking for. The closest 17" size in overall diameter to the original 14" is actually 225/45-17. But these days many people don't want tires as tall as the stock 14" - one of the more popular 15" choices is 225/50-15, which is significantly shorter than the original. Link to comment https://www.classiczcars.com/forums/topic/18046-centerline-17-wheels/#findComment-146238 Share on other sites More sharing options...
November 16, 200519 yr comment_146250 205/40's have too small of a sidewall. The car will handel better with a 45 or 50. 205/50/17 (the one I would run) is the correct height tire as well as what Arne said. Link to comment https://www.classiczcars.com/forums/topic/18046-centerline-17-wheels/#findComment-146250 Share on other sites More sharing options...
November 16, 200519 yr comment_146254 farwest said: Just bought a set of 17" x 7"with the correct 4" backspace centerline wheels for my stock ride height 73 240z what tire size fits best? I've think 205/45/17 or is it 205/40/17 ? any help would be appreciated thanks.Pictures??? Link to comment https://www.classiczcars.com/forums/topic/18046-centerline-17-wheels/#findComment-146254 Share on other sites More sharing options...
November 16, 200519 yr comment_146260 zguitar71 said: 205/40's have too small of a sidewall. The car will handel better with a 45 or 50. 205/50/17 (the one I would run) is the correct height tire as well as what Arne said.Yeah, the 205/50-17 is probably a better size for 7" wide wheels. Link to comment https://www.classiczcars.com/forums/topic/18046-centerline-17-wheels/#findComment-146260 Share on other sites More sharing options...
November 17, 200519 yr Author comment_146295 Made by centerline. Thanks for the help! Link to comment https://www.classiczcars.com/forums/topic/18046-centerline-17-wheels/#findComment-146295 Share on other sites More sharing options...
November 17, 200519 yr comment_146314 Nice looking set of wheels! Did you order them direct from Centerline? Link to comment https://www.classiczcars.com/forums/topic/18046-centerline-17-wheels/#findComment-146314 Share on other sites More sharing options...
October 3, 200618 yr comment_184498 If the the car is lowered 1 1/2 " Wil the 205/50-17 tires still work? Link to comment https://www.classiczcars.com/forums/topic/18046-centerline-17-wheels/#findComment-184498 Share on other sites More sharing options...
October 3, 200618 yr comment_184506 I run 215/45R17 Wanli's on my 17x7 RacingHart C2's with spacers from MM. Link to comment https://www.classiczcars.com/forums/topic/18046-centerline-17-wheels/#findComment-184506 Share on other sites More sharing options...
October 10, 200618 yr comment_185310 I have Koning Imagine 17x7 and not sure on wheel size.Eibach Pro-Kit, tokico Iluminas adjustables on a 1973.My brakes are Wilwood. Im going to put all parts together for the first time.What size should be the best 205/50/17 or 215/50/17 or can I go wider? 225 the most.Thank You. Link to comment https://www.classiczcars.com/forums/topic/18046-centerline-17-wheels/#findComment-185310 Share on other sites More sharing options...
October 10, 200618 yr comment_185321 Gentlemen-So we have a question of overall tire height/diameter vs. aspect ratio or profile.The overall height of a stock 175/70-14 is not significantly taller than a 205/50-15 or a 205/45-17 as this should be maintained for minimal speedometer error.Yes, their profiles are lower (sidewall height decreases) but the overall heights/diameters are not too different.But a 205/50-17 actually creates a taller overall height than stock, even though the profile is lower.Got it.If this is not clear, refer to the 10/10 tires link CDAVID suggested and see the comparisons. Link to comment https://www.classiczcars.com/forums/topic/18046-centerline-17-wheels/#findComment-185321 Share on other sites More sharing options...
