Datsun E 31 crank out of a P30 block from a 1972 240Z.
This crank has but only 10K miles on it. It has been balanced and is still very clean. A great crank to replace one that you might have bad or need to replace for a fraction of the cost of new. Email me for more photos. The price is 120.00 obo
Datsun 240Z connecting rods (9mm) and pistons.
Here is a excellent set of used connecting rods and pistons for your 240Z. In great shape with only 10K miles on them. They're still like new, Nissan ampco aluminum pistons. great for your future rebuild and much less then the cost of new. Nismo parts sells connecting rods alone for 69.00 a piece, not to include pistions at 40.00 each. Get the whole lot for 200.00 obo.
Datsun E88 Performance Head
Comeplete rebuild on this E88 head was done with the rest of my motor parts. With only 10K miles this is a great head to get that power your wanting from your 2.8 block to make a good 10:1 compression engine for some serious power. It had been cleaned, refinished, has had the larger 44mm intake and 35mm exhaust valves installed, new steel seats, guides, springs, retainers, rocker arm kit, and lash pad kit. Alson installed was a 480 lift 274 duration cam thast good for power from 2500 to6000 rpms. A great start to a good performing engine. 400.00 obo
Datsun E31 Head.
Complet E31 head from a 1971 240Z. The car was running when the head was pulled. It is in good condition and is bolt on ready to go. 150.00
Tripple Dell Orto 40mm carbs and Cannon Intake Manifold
Add power to your car with this tripple carb set up. 40mm Dell Orto carbs and Cannon intake make for a great combo of power. the carbs are ready to go with new bolts. All you need are air cleaners which are sold for a rather cheap price constantly on ebay and linkage. These are a lot easier to set up then the Webers there made after and will give you all you need to make your carbureted Z go. 400.00 obo
Datsun ZX early distributor
79-80 model remanufactured ZX distributor for your Datsun. Bought new only 7 months ago, this is the best option for going to electronic ignition on your 240 Z. In excellent shape with the 12-80 module for the best performance. Still has remaining warranty on the part and i have a reciept. if you have been looking for a good ignition upgrade this is it. 85.00 obo
Datsun 6 into 2 header
I have a Datsun 6 into 2 header of unkown make for the L6 square port exhaust engine. looks to be in great shape with just a little surface rust which will clean up easily . 50.00
I have a few other things for sale that i have to get ready. Up for sale soon will be a set of 280ZX six spoke wheels that have to be repolished price 200.00 for the set of 5! will have pics to follow. A good set of 72 240 Z seats in great condition also for sale ready to bolt in 150.00 obo. I have a few other odds and ends that are for n/a applications. Im going turbo and building a new engine. I will also have for sale shortly once the trubo engine is done a complete engine w/89k original miles and E31 head for sale. A good set of 3 screw su's and a 4 speed.
heres the website link for pics.
http://communities.msn.com/240Z1972/shoebox.msnw
email me at jaymes240@hotmail.com if you have any questions
thanks
