Email logins are now active ×
Bubbles in Clutch MC after bleeding
BillD
My clutch felt sloppy, so I checked the fluid and it was very low. I filled it, but it obviously needing bleeding. I bled (with a vacuum pump) and it now works beautifully, but very tiny bubbles appear in the master cylinder when pumping the clutch. Do I need a rebuild kit or new MC?
I had the same problem only the bubbles in mine were big. Your Clutch MC has a piston inside it to push and pull the fluid when you put your foot down on it. The Valve inside the assy. has little rubber "O" rings. Mine was tearing apart, letting air in and fluid out. Your best bet would be to take yours apart and inspect the rings. If it is looks torn, find a used one in good condition. I found mine on EBay for really cheap. Good luck my friend.
  • Who's Online   2 Members, 0 Anonymous, 570 Guests (See full list)
