Funny turn signal issue.....
uhoh7
Hi guys
73 240 box stock
Right turn sig is perfect.
Left turn: rear light flashes, but no flash in dash or front left.
The bulb and wire to the harness in front are fine: i checked. I pluged the left front harness in to the right socket behing the grill and it flashes fine
The flasher thingy (round plugs in under dash) is good, I swaped it out: same thing.
Any suggestions would be greatly appreciated
if you read my post you'll see I have emliminated that possiblity.
upon serching it looks like it could be the combo switch on the wheel. I'm gonna spray some contact cleaner in there.
I didn't see how it could be the combo, since my rear blinker works, but one guys swears that bad combo contacts can produce these symptoms
BTW my hazard lights work perfectly.
