71_240Z Posted November 20, 2005 Share #1 Posted November 20, 2005 My rear skirt is mangled pretty bad - especially around the tail pipe. I guess I have to cut out the whole thing and reweld another one. Im exploring alternatives, but I dont really like the rear ground effect kits too much although it seems like a good solution to solve the cosmetic problem. Has anyone every replaced this part? It looks like I have to cut it out and hire a welder. I cant find any bolts. I was hoping for a bolt off / bolt on job.Do you have a straght one you can send me? Am I missing something? It does have to be welded, right? Link to comment Share on other sites More sharing options...
kenz240z Posted November 20, 2005 Share #2 Posted November 20, 2005 If I were going to do this, I'd use a spot weld cutter. It is kind of like a miniature hole saw. To use it, you have to locate the center of the spot weld. Then use a center punch to make a dimple, then cut out the spot weld. Once all of them are cut out the skirt will come right off.I'm not sure if replacements are available, you might have to find one in a salvage yard. If you find a suitable donor car in the salvage yard, use the spot weld cutter to remove the skirt. If you use the spot weld cutter with a cordless drill, plan on having several spare, charged batteries.I think Eastwood (www.eastwood.com) carries the spot weld cutters. I bought mine at a local parts house. Link to comment Share on other sites More sharing options...
texasz Posted November 20, 2005 Share #3 Posted November 20, 2005 Do you have a straght one you can send me?If you end up deciding that you need one please let me know as I believe I have one that I can remove for you (I have two parts cars and I think that this part is good on one if not both of them, would have to go out to where they are stored to verify this). Link to comment Share on other sites More sharing options...
MarkDixon Posted November 20, 2005 Share #4 Posted November 20, 2005 MSA has the replacement panel that goes there.www.zcarparts.com Link to comment Share on other sites More sharing options...
71datsunZ Posted November 20, 2005 Share #5 Posted November 20, 2005 msa is out of stock... a lot of people are backordered Link to comment Share on other sites More sharing options...
J P D Posted November 21, 2005 Share #6 Posted November 21, 2005 just get someone that can do paintless dent removal to knock it out. thats what im doin with mine, which is mangled pretty badly. they would have real easy access to get behind the panel and beat it back into shape. and it might be cheaper and less time consuming than welding in a new panel Link to comment Share on other sites More sharing options...
gnosez Posted November 22, 2005 Share #7 Posted November 22, 2005 MSA gets their panels from Charlie Osborne at Zeddfindings (www.datsunzparts.com) up in Canada. Contact him directly. They need to be rolled to fit correctly. Take measurements before removing yours as it can make replacing the gas tank impossible if you make it too small an opening.This is not as easy as it looks....good luck. Link to comment Share on other sites More sharing options...
