Posted November 28, 200519 yr comment_147645 I have a late 72 (L24), oil pan and a L28 oil pan, and I can't tell the difference. I've read elsewhere that there is a difference, but I can't seem to find one. Is there really a difference?Thanks,Pete Link to comment https://www.classiczcars.com/forums/topic/18184-late-l24-oil-pan-vs-l28-pil-pan/ Share on other sites More sharing options...
November 28, 200519 yr comment_147647 IIRC the L28 pan has a shorter and straighter pickup. The L24 has a longer pickup that sits further back in the oil pan. I think ***but I'm not sure*** that the L24 pan has the baffle further back as well to match the pickup.I ran into this problem when I bought the AZC aluminum pan and had the wrong pickup a few years back, and I believe this was the cause. Link to comment https://www.classiczcars.com/forums/topic/18184-late-l24-oil-pan-vs-l28-pil-pan/#findComment-147647 Share on other sites More sharing options...
November 28, 200519 yr comment_147681 does the AZC have the longer pickup (L24) or the shorter one?Was just about to get one for my L24! Link to comment https://www.classiczcars.com/forums/topic/18184-late-l24-oil-pan-vs-l28-pil-pan/#findComment-147681 Share on other sites More sharing options...
November 28, 200519 yr comment_147683 Shorter 280Z pickup IIRC. Call Dave. He can tell you for sure. Link to comment https://www.classiczcars.com/forums/topic/18184-late-l24-oil-pan-vs-l28-pil-pan/#findComment-147683 Share on other sites More sharing options...
