Hello, I have a 1983 280zx turbo. The impeller on the turbo is broken. I am not having any luck at all finding a used one locally. Does someone have one that they would be willing to sell me?
https://www.classiczcars.com/forums/topic/18205-need-help-finding-a-turbo/
An entire new cartridge is about $150 and you then have a completely rebuilt unit. Why go cheep just to find out running imballanced has messed up the bushings...
Will
If you really want a used one, I may have one .
What all does the cartridge include and where do I get one. I called a turbo shop here in Oklahoma and he looked it up and told me if the shaft was broken I would need a new "center piece" and said it would be $600.00.
Well someone is ripping you off if the are charging you 600 dollars for a new ?center section" Cartridge as hls30 has properly called it.
My new Garret T3/T4 cost just over 600, so if that tells you anything then you might want to reconcider.
Go to www.speedshopthagard.com he is a reputable seller and aslo a Zcar owner. You can go wrong with James Thagard, he knows his business and what hes talking about.
Good luck
I haven't found the packing invoice from my pruchase, but when I get home, I will go through my paypal history and try to find where I sent payment.
Will
