Email logins are now active ×
Transmission serial number
CrashNBurn
I have a 1973 240Z with a vin of HLS30-163077. It has a five speed transmission in it, but I am not sure which type it is, an original five-speed or a later version. I found a serial number stamped on the top of the bell housing, 7730292. Can the type of transmission in the car be identified by this, or do I have to pull it from the car to find out? I checked my microfiche CD and can’t find this number anywhere. Are than any other numbers stamped on the transmission that can be used for identification? If it helps, the shift lever is the bent type.
Jason
Here in the US, there was no factory option of a five speed for any 240 or 260Z. The five speeds weren't offered by Nissan here until the '77 model year.
That said, you may be able to identify which type five speed you have using the info on these pages:
http://www.geocities.com/inlinestroker/ratio.html
http://www.gracieland.org/cars/techtalk/gearing2.html
  • 1 year later...
  • Who's Online   2 Members, 0 Anonymous, 201 Guests (See full list)
