Posted December 13, 200519 yr comment_148971 Can anyone help me tell if either my car is a 240Z or a 280Z, it is a pretty odd car, inside has the dash of a 280Z, the engine and tranny looks like the 240Z. The gas tank was a 240Z. also i found an ecu on the car. By know the car is half & half, jajaja.:stupid: Link to comment https://www.classiczcars.com/forums/topic/18295-how-can-you-tell-a-240z-from-a-280z/ Share on other sites More sharing options...
December 13, 200519 yr comment_148974 Well what is the vin number? Link to comment https://www.classiczcars.com/forums/topic/18295-how-can-you-tell-a-240z-from-a-280z/#findComment-148974 Share on other sites More sharing options...
December 14, 200519 yr comment_149005 Might have more than one VIN, , if that dash came from a 280. Check the firewall stamp and let us know, we'll get you straightened out. Link to comment https://www.classiczcars.com/forums/topic/18295-how-can-you-tell-a-240z-from-a-280z/#findComment-149005 Share on other sites More sharing options...
December 14, 200519 yr comment_149021 Look at the frame rails. They are long on the 280Z. The 280Z bumpers are completely different. Link to comment https://www.classiczcars.com/forums/topic/18295-how-can-you-tell-a-240z-from-a-280z/#findComment-149021 Share on other sites More sharing options...
December 14, 200519 yr comment_149026 in the engine compartment , on the firewall just left of the master cylinder there should be a series of numbers and letters stamped into the firewall. Tell us what they are . This is the vin number .:rambo: add your location to the profile. is this a right or left hand drive? Link to comment https://www.classiczcars.com/forums/topic/18295-how-can-you-tell-a-240z-from-a-280z/#findComment-149026 Share on other sites More sharing options...
December 14, 200519 yr comment_149028 Gee and i thought my car had problems!Whats the production date? Link to comment https://www.classiczcars.com/forums/topic/18295-how-can-you-tell-a-240z-from-a-280z/#findComment-149028 Share on other sites More sharing options...
December 14, 200519 yr comment_149034 We don't have 280Zs here, but you can tell a 240Z from a 260Z by the tail-lights. The reverse lights are separate from the others on the 260Z. The same might apply for the 280Z.Other obvious things are:badgesare there rear seats (the 240Z didn't have a '2+2' model)?bumpers are different, I think, aswell.flutes in the bonnet (sorry, 'hood'), the these are not original on the 240Z but might have been fitted by the owner.monkeyman Link to comment https://www.classiczcars.com/forums/topic/18295-how-can-you-tell-a-240z-from-a-280z/#findComment-149034 Share on other sites More sharing options...
December 15, 200519 yr Author comment_149134 thanks, hmm the dash VIN# HLS30 216985, but then again as Virto said it might have other numbers...for the bumpers well it only has one in the front, the rear bumper was removed and then the holes where covered by bondo, jaja also I've found I have an L26 engine with SU carbs, jaja. I'll check the firewall, and post on friday night, jeje since the car is not completely legal and is currently at mexico jajaja, border cities.... Link to comment https://www.classiczcars.com/forums/topic/18295-how-can-you-tell-a-240z-from-a-280z/#findComment-149134 Share on other sites More sharing options...
December 15, 200519 yr comment_149141 I believe a vin in the 216 hundred thounsand should be a 260Z right? if that is indeed the correct vin Link to comment https://www.classiczcars.com/forums/topic/18295-how-can-you-tell-a-240z-from-a-280z/#findComment-149141 Share on other sites More sharing options...
December 16, 200519 yr comment_149169 240Z from 280Z?compare the bumpers, location of turn signal lights, or the tailights.280Z bumpers ::i think:: have shocks in the rear for improved safety so the bumper sticks out more.280Z turn signal lights are located in the grill, whereas the 240Z turn signals are bigger and located under the bumper. Link to comment https://www.classiczcars.com/forums/topic/18295-how-can-you-tell-a-240z-from-a-280z/#findComment-149169 Share on other sites More sharing options...
December 16, 200519 yr comment_149184 What year is your car?? do you know for sure? that would be to easy!! Link to comment https://www.classiczcars.com/forums/topic/18295-how-can-you-tell-a-240z-from-a-280z/#findComment-149184 Share on other sites More sharing options...
December 16, 200519 yr comment_149255 weigh the bloody thing... if it's more than 2200 lbs you got a 280. Link to comment https://www.classiczcars.com/forums/topic/18295-how-can-you-tell-a-240z-from-a-280z/#findComment-149255 Share on other sites More sharing options...
