Posted December 16, 200519 yr comment_149168 Somebody is selling motor upgrade from a Honda blower for our weak OEM Z motors.Anybody has some comments about fit, finish and performance versus our original unit?Which Honda model and year is it coming from? Link to comment https://www.classiczcars.com/forums/topic/18310-heaterac-motor-upgrade-for-240z/ Share on other sites More sharing options...
December 16, 200519 yr comment_149173 http://www.classiczcars.com/forums/search.php?searchid=164291 Link to comment https://www.classiczcars.com/forums/topic/18310-heaterac-motor-upgrade-for-240z/#findComment-149173 Share on other sites More sharing options...
December 16, 200519 yr comment_149191 Were you trying to link to this one?http://www.classiczcars.com/forums/showthread.php?t=19709&highlight=Honda+blower Link to comment https://www.classiczcars.com/forums/topic/18310-heaterac-motor-upgrade-for-240z/#findComment-149191 Share on other sites More sharing options...
December 16, 200519 yr comment_149200 sblake01 said: Were you trying to link to this one?http://www.classiczcars.com/forums/showthread.php?t=19709&highlight=Honda+blowerI believe that is one in the search I was trying to post. Thanks.This is what I meant to posthttp://www.classiczcars.com/forums/search.php?searchid=164401 Link to comment https://www.classiczcars.com/forums/topic/18310-heaterac-motor-upgrade-for-240z/#findComment-149200 Share on other sites More sharing options...
December 16, 200519 yr comment_149233 Still doesn't work, at least, not for me. Link to comment https://www.classiczcars.com/forums/topic/18310-heaterac-motor-upgrade-for-240z/#findComment-149233 Share on other sites More sharing options...
December 17, 200519 yr comment_149263 sblake01 said: Still doesn't work, at least, not for me.http://www.classiczcars.com/forums/search.php?searchid=164607Thanks for the heads up, Steve. I'm trying it again, and I just used the link and it worked for me "now". Of course I did the same thing when I posted the previous times, but for some reason the links seem to DIE.Anyway, all anyone needs to do is use "Honda" and "blower" as search terms and 13 threads pop up. Most (but not all) of them have nuggets of info that will help a 240Z owner. Link to comment https://www.classiczcars.com/forums/topic/18310-heaterac-motor-upgrade-for-240z/#findComment-149263 Share on other sites More sharing options...
December 17, 200519 yr comment_149264 Ah, you've likned to all of the threads on the subject:devious: Link to comment https://www.classiczcars.com/forums/topic/18310-heaterac-motor-upgrade-for-240z/#findComment-149264 Share on other sites More sharing options...
December 17, 200519 yr comment_149268 sblake01 said: Ah, you've likned to all of the threads on the subject:devious:YES! There are nuggets of info in many of the threads, and, IMO NONE of the threads covered ALL of the info I'd want to know about the subject.:pirate: Link to comment https://www.classiczcars.com/forums/topic/18310-heaterac-motor-upgrade-for-240z/#findComment-149268 Share on other sites More sharing options...
December 17, 200519 yr comment_149269 montoya_fan01 said: YES! There are nuggets of info in many of the threads, and, IMO NONE of the threads covered ALL of the info I'd want to know about the subject.:pirate:Sounds like a project for someone who's done it. Link to comment https://www.classiczcars.com/forums/topic/18310-heaterac-motor-upgrade-for-240z/#findComment-149269 Share on other sites More sharing options...
December 17, 200519 yr comment_149279 Montoya I believe the search ID you are providing a link to is a randomly generated number that is either cookie based or simply goes away after a time. Anyway, it's simple enough to search for honda + blower as you suggested. I found out today that my blower is dead as well. I had never actually tried it. guess I'll add this to my to-do list. Link to comment https://www.classiczcars.com/forums/topic/18310-heaterac-motor-upgrade-for-240z/#findComment-149279 Share on other sites More sharing options...
December 17, 200519 yr comment_149296 =Enigma= said: Montoya I believe the search ID you are providing a link to is a randomly generated number that is either cookie based or simply goes away after a time. Anyway, it's simple enough to search for honda + blower as you suggested.I found out today that my blower is dead as well. I had never actually tried it. guess I'll add this to my to-do list. yeah, I think you're right. The friggin link is dead again. another new bug in the system. too bad. in cases like this a list of search results can really help someone find a lot of information. Link to comment https://www.classiczcars.com/forums/topic/18310-heaterac-motor-upgrade-for-240z/#findComment-149296 Share on other sites More sharing options...
December 17, 200519 yr comment_149321 Hey there Garth,A list of search results is a great idea.Since you suggested it, why not check with Mike to see how/where/when/if it can be done, then do it for him. It would certainly be a big help to everone, especially newbies. Can't expect Mike to do everything now,can we?.Rick.:devious: :devious: Link to comment https://www.classiczcars.com/forums/topic/18310-heaterac-motor-upgrade-for-240z/#findComment-149321 Share on other sites More sharing options...
