I just picked up a 72 240z yesterday. I will try to get some pictures posted. I do have a question. There is a box on the inner fender well that has a the speedo cable connected to it then to the speedo. It also has a vacume line connected to it. The care is in good shape with nice floors and a clean paint job. It will be a great daily driver.
https://www.classiczcars.com/forums/topic/1834-new-z/
I usually refer to things such as this as the 'Jesus ____'. Let me explain. One of my first Z's was a '80 280ZX. Off the battery was th usual positive/negative wires. Coming out of the firewall was a small speaker wire connecting to the positive lead. I never identified it, but if unplugged; the car would not run. After sever hours with an electrician friend of mine, he sat up. Smiled, and proudly proclaimed it was a 'Jesus wire'. He explained it was a 'Jesus wire' because Jesus is the only one who knows why its there. His advice: if the car functions normally then leave it. So my advice: if the car functions normally, leave the box.
https://www.classiczcars.com/forums/topic/1834-new-z/#findComment-8229
If the speedomer cables routes through this, it may be a set of gears to get the speedometer to register correctly if the wheel/tire diameter was changed from stock.
Reminds me of a friend with a VB bug who kept getting tickets. He couldn't figure out why the speedometer showed 12MPH slower than he really was going - he took it to a speed-o shop and they installed a gear reduction box and he was reading correctly since the tires were larger diameter than the speedometer was built for.
I'm not quite sure why it needs a vacuum line.
This is my best quess.
Rick
https://www.classiczcars.com/forums/topic/1834-new-z/#findComment-8230
