Posted December 24, 200519 yr comment_149963 Hi, I just installed a set of Konig Rewinds on my 70 Z. I bought them from MSA but could not get the center caps on. Anyone else run into this problem?Any solutions?Mark Link to comment https://www.classiczcars.com/forums/topic/18373-konig-rewinds/ Share on other sites More sharing options...
December 24, 200519 yr comment_149967 Yes, I've seen other complaints on this as well. The caps aren't deep enough to clear the 240Z hubs and dust covers. Some people simply leave the caps off, or you could put a 1/4" spacer behind the wheel. Or I suppose you could convert to 280Z hubs and rotors, but that seems excessive to me. Link to comment https://www.classiczcars.com/forums/topic/18373-konig-rewinds/#findComment-149967 Share on other sites More sharing options...
December 24, 200519 yr comment_149976 You could try flattening the caps with a big hammer Link to comment https://www.classiczcars.com/forums/topic/18373-konig-rewinds/#findComment-149976 Share on other sites More sharing options...
December 24, 200519 yr comment_149982 I have a '77... flattened my grease caps "gently" with a hammer, and the caps then fit. Have heard of others with earlier 1st-gens that were unable to get the caps to fit. Link to comment https://www.classiczcars.com/forums/topic/18373-konig-rewinds/#findComment-149982 Share on other sites More sharing options...
December 24, 200519 yr Author comment_149986 Thanks, I will try flattening the dust caps. Link to comment https://www.classiczcars.com/forums/topic/18373-konig-rewinds/#findComment-149986 Share on other sites More sharing options...
December 25, 200519 yr comment_150026 You can always get another set of dust caps on ebay for like $10 Link to comment https://www.classiczcars.com/forums/topic/18373-konig-rewinds/#findComment-150026 Share on other sites More sharing options...
December 25, 200519 yr comment_150050 You think you have centre cap problems......... you dont want to hear my story!! Good luck to you - looks like flattening the dust caps is the best (ie cheapest and easiest) answer. Link to comment https://www.classiczcars.com/forums/topic/18373-konig-rewinds/#findComment-150050 Share on other sites More sharing options...
