Posted December 29, 200519 yr comment_150450 need thread size for the oil pan plug...is it NPT?? Metric?? Link to comment https://www.classiczcars.com/forums/topic/18415-anyone-anyone-know-the-thread-size/ Share on other sites More sharing options...
December 30, 200519 yr Author comment_150520 35 views?....nobody knows? Link to comment https://www.classiczcars.com/forums/topic/18415-anyone-anyone-know-the-thread-size/#findComment-150520 Share on other sites More sharing options...
December 30, 200519 yr comment_150536 I might do a little research for you if no one answers. Heck, I'll do it anyway, I'd like to know the answer. I have an old drain plug and I work at a hardware store that has a thread size check board. I won't be back there until Tuesday however, four day weekend you know. Link to comment https://www.classiczcars.com/forums/topic/18415-anyone-anyone-know-the-thread-size/#findComment-150536 Share on other sites More sharing options...
December 30, 200519 yr comment_150537 Was digging around last night, but could not find the specs. Probably the same luck the other 34 are having (plus yourself). Link to comment https://www.classiczcars.com/forums/topic/18415-anyone-anyone-know-the-thread-size/#findComment-150537 Share on other sites More sharing options...
December 30, 200519 yr comment_150543 See Ebayhttp://cgi.ebay.com/ebaymotors/Datsun-240Z-260Z-280Z-280ZX-Drain-Plug-and-Washer-NOS_W0QQcmdZViewItemQQcategoryZ10076QQitemZ4600743695QQrdZ1QQsspagenameZWDVWThis seller is Jim B at Wendle Nissan Spokane, WA. Found him to be more then helpful.So, both parts are stocked some place in Nissans warehouse system. Link to comment https://www.classiczcars.com/forums/topic/18415-anyone-anyone-know-the-thread-size/#findComment-150543 Share on other sites More sharing options...
December 30, 200519 yr Author comment_150550 I think i found it... I think it's a 16.4mX1.33 ... sounds like an oddball size... i was hoping it was a 16M X 1.5, (there's an adapter for that size)... oh, well.. I have an extra plug... might just try tapping a 1/8 npt thread in that... I just don't want to mess with the oil pan if I don't have to... (putting in a oil temp sending unit in) Link to comment https://www.classiczcars.com/forums/topic/18415-anyone-anyone-know-the-thread-size/#findComment-150550 Share on other sites More sharing options...
December 30, 200519 yr comment_150556 That sounds right. I just took my pan off to replace the gasket. My thread gauge didn't match with either 1.5 or 1.25 pitch, both were close but not quite. and it was bigger than 16 mm, but smaller than 17 mm. So I think you've got it figured out. Link to comment https://www.classiczcars.com/forums/topic/18415-anyone-anyone-know-the-thread-size/#findComment-150556 Share on other sites More sharing options...
