January 8, 200619 yr comment_151400 You're welcome. Some day I may get around to doing this type of things for others. But I should have believed you when you talked about how much time it takes. I'd like to do things like this, but right now I need to spend more time on my car. My goal is to have it finished in 18-21 months. We'll see... Link to comment https://www.classiczcars.com/forums/topic/18416-anybody-building-headlight-relay-harness/?&page=5#findComment-151400 Share on other sites More sharing options...
January 8, 200619 yr comment_151426 Ok gents. I've added the overall wiring harness pic and posted the document on my web server.http://www.jaderunner.com/Auto/240Z/Docs/daves_harness.docDave, it might make sense to edit your original post and add in this URL for convenience before we get too many references to this file going in this thread. Link to comment https://www.classiczcars.com/forums/topic/18416-anybody-building-headlight-relay-harness/?&page=5#findComment-151426 Share on other sites More sharing options...
January 9, 200619 yr comment_151500 Not that there is anything wrong with the .gif image that Arne posted, but if someone wants the diagram in a slightly larger image, here is a .jpeg that just about fills a 1024X768 screen at less than 60kb file size Link to comment https://www.classiczcars.com/forums/topic/18416-anybody-building-headlight-relay-harness/?&page=5#findComment-151500 Share on other sites More sharing options...
January 9, 200619 yr comment_151501 Any improvement apon existing drafts and graghs will not be discouraged. But mearly thanked for.Thanks, and any improvements that any one else make are more than welcome.Dave Link to comment https://www.classiczcars.com/forums/topic/18416-anybody-building-headlight-relay-harness/?&page=5#findComment-151501 Share on other sites More sharing options...
January 9, 200619 yr comment_151502 May sound stupid but as far as I can tell the end conector circled in red goes to the switch. Link to comment https://www.classiczcars.com/forums/topic/18416-anybody-building-headlight-relay-harness/?&page=5#findComment-151502 Share on other sites More sharing options...
January 9, 200619 yr comment_151505 It goes to the stock harness where you pulled the headlight plug from.It is a male plug (just like the stock headlight plug) and plugs into the stock harness as an input for the relays.Any other questions? if so, try this one. It's ALL in there http://www.classiczcars.com/forums/showthread.php?t=20016&highlight=headlight+diagram Link to comment https://www.classiczcars.com/forums/topic/18416-anybody-building-headlight-relay-harness/?&page=5#findComment-151505 Share on other sites More sharing options...
February 10, 200619 yr comment_155332 Here's a link to the headlight harness's that I'm making again.http://www.classiczcars.com/forums/showthread.php?p=161987#post161987 Link to comment https://www.classiczcars.com/forums/topic/18416-anybody-building-headlight-relay-harness/?&page=5#findComment-155332 Share on other sites More sharing options...
