4 wire to 3 wire tach
ricksaia
Hello all, has anyone out there changed the tach from a four wire to a three wire in a 1970 240Z? Could you let me know how you did the wiring. I installed a distributer and a coil from a 1983 ZX. Of course my tach stopped working. I have the three wire unit, I just need to know how to wire it. Cannot find it anywhere in the forums. Please help. Rick.
Arne, I used the coil from the ZX and bypassed the ballast resister by connecting the black/white wire to the green/white wire. I don't know why it is not working. So I want to use the 280Z tach, but I don't know how to wire it. Enrique, do you have any input?
Thanks, Rick.
Some more questions, Rick.
1.) I assume that the car is running OK, just no tach?
2.) On the ZX coil - you should have a wire from each terminal of the coil going to the twin terminal connector on the distributor box, and the other black/white wire connected to the + terminal of the coil. So two wires on the + and only one on the - terminal. All sound right?
  • Who's Online   1 Member, 0 Anonymous, 475 Guests (See full list)
