April 7, 200619 yr comment_162564 Here is a picture of the door latch adjusting plate with the quarter panel cut out. I still believe that you can get lock nuts on those bolts after taking this picture. Will take some time and a couple of tries but, I think time still well spent. Link to comment https://www.classiczcars.com/forums/topic/18503-re-tapping-receiver-plate-inside-door-jamb/?&page=4#findComment-162564 Share on other sites More sharing options...
April 7, 200619 yr Author comment_162606 Jim,On my '73, there's a piece of metal that partially blocks my attempts to add extra nuts onto the end of the bolts. I don't see it in your picture. That's a pic of the passenger side, correct?-Ken Link to comment https://www.classiczcars.com/forums/topic/18503-re-tapping-receiver-plate-inside-door-jamb/?&page=4#findComment-162606 Share on other sites More sharing options...
April 16, 200618 yr comment_163732 Yes, that picture is from the right side but, on mine the drivers is a mirror image. It is a clear shot but, at alittle angle. I will look at a 73 here soon and see the difference. Link to comment https://www.classiczcars.com/forums/topic/18503-re-tapping-receiver-plate-inside-door-jamb/?&page=4#findComment-163732 Share on other sites More sharing options...
May 26, 200618 yr comment_168832 On that captive plate, can it be easily removed once an access hole is made from behind the dogleg? Or did they spot weld that angled plate in thereso it stays in place? My top bolt on my latch stripped the other day, and I was thinking I'd weld a nut in place.Dave Link to comment https://www.classiczcars.com/forums/topic/18503-re-tapping-receiver-plate-inside-door-jamb/?&page=4#findComment-168832 Share on other sites More sharing options...
May 26, 200618 yr comment_168833 There are three spot welds that hold the bracket in place see the picture in post # 37. I don't see why you could not open up the dog leg panel tack the nut in place and weld the panel back up. You may need to replace the metal with a new piece and then refininsh the repair and put the dog leg back in place. Link to comment https://www.classiczcars.com/forums/topic/18503-re-tapping-receiver-plate-inside-door-jamb/?&page=4#findComment-168833 Share on other sites More sharing options...
September 7, 200618 yr comment_181439 I've just struck what I believed to be the same problem, however while the symptoms are identical the fix is different. For those that think that the thread is stripped in the capitive nuts read on....After re-reading this thread, I had come to the conclusion that I was in deep poo and the only way would be to use the above methods to mount a captive nut on the adjusting plate. So, I removed one bolt so I could match it up with a nut, surprisingly on inspection the bolt had actually stripped the thread high up near the top. The fix was to obtain a couple of metric bolts, grind the end to a taper.Nissan no longer hold the bolt in stock (in Aus.) Link to comment https://www.classiczcars.com/forums/topic/18503-re-tapping-receiver-plate-inside-door-jamb/?&page=4#findComment-181439 Share on other sites More sharing options...
September 7, 200618 yr comment_181443 Mike;You must just live right. I say you made out alright on that one. Normally the plate strips out first. Good to hear that you just had to replace the bolt. Link to comment https://www.classiczcars.com/forums/topic/18503-re-tapping-receiver-plate-inside-door-jamb/?&page=4#findComment-181443 Share on other sites More sharing options...
September 7, 200618 yr Author comment_181556 I agree Mike you came out plain lucky on that one. The Z-car gods have smiled upon you, take her out for a spin! Link to comment https://www.classiczcars.com/forums/topic/18503-re-tapping-receiver-plate-inside-door-jamb/?&page=4#findComment-181556 Share on other sites More sharing options...
April 27, 201311 yr comment_421768 Hate to bump an old thread but this was a real pain for me as well...mine was stripped on the driver's side top. I pulled all the original (and recently plated) bolts and discovered a) I could reach the back of the top hole via the 1" access hole after removing the dogleg interior panel and that one bolt was longer than the other 2 so I simply used the longest bolt on the top, taped an appropriate nut onto my finger to get it threaded onto the bolt and had it all wrapped up 10 minutes later. I may pop the nut off and put some thread lock on it or something as there isn't enough thread to mount a second, I think at least....to snug it down I simply locked it with a flathead screw driver and it worked no problem. Link to comment https://www.classiczcars.com/forums/topic/18503-re-tapping-receiver-plate-inside-door-jamb/?&page=4#findComment-421768 Share on other sites More sharing options...
April 29, 201311 yr Author comment_421935 No worries ollie, what's 6-1/2 years between posts? :-) Just consider youself lucky Link to comment https://www.classiczcars.com/forums/topic/18503-re-tapping-receiver-plate-inside-door-jamb/?&page=4#findComment-421935 Share on other sites More sharing options...
