Posted January 13, 200619 yr comment_151933 Just a note to say that I have an L28et with the P90a is a solid lifter configuration. It has been said that these didn't exist or only came from the Japanese market. I don't yet know if I'll hold on to it, sell it complete, break it for parts or move the head and turbo over to my triple Dellorto L24...decisions...decisions. I'm breaking down the whole car so if anyone needs a particular part let me know. I'll be posting bits to eBay shortly. Link to comment https://www.classiczcars.com/forums/topic/18544-82-280zxt-p90a-with-solid-lifters/ Share on other sites More sharing options...
January 13, 200619 yr comment_151958 There is nothing special about it, there were are P90a heads that have solid lifters. Better for you in the long run when you are wanting to make more power out of the head. Link to comment https://www.classiczcars.com/forums/topic/18544-82-280zxt-p90a-with-solid-lifters/#findComment-151958 Share on other sites More sharing options...
January 15, 200619 yr comment_152128 I have a set of hydraulic lifters that we are going to modify. It will be an interesting project to convert these lifters. We will have the option of running a solid lifter camshaft if we can master these lifters. I do not see the rationale for the solid lifters if we do not go with a very high performance cam. I think the hydraulic lifters are the answer as long as you keep the lift at .500 or less and do not run a lot of spring pressure. Now if you are racing, that's another story. I like my quiet lifters and no-nonsense camshaft (for now!). I am guessing there is no way to know whether a P90A head is solid or hydraulic out of a yard. You really must pull the valve cover to see what it is running. Link to comment https://www.classiczcars.com/forums/topic/18544-82-280zxt-p90a-with-solid-lifters/#findComment-152128 Share on other sites More sharing options...
January 15, 200619 yr Author comment_152147 For my use the hydraulic lifters would be fine but I do like the tick of a solid lifter valvetrain. It reminds my of hipo chevy smallblocks I built many years ago. I only posted because I'd read in several post that the P90a head was no often found with solid lifters. I guess that was incorrect. Link to comment https://www.classiczcars.com/forums/topic/18544-82-280zxt-p90a-with-solid-lifters/#findComment-152147 Share on other sites More sharing options...
January 15, 200619 yr comment_152148 I certainly wouldn't be averse to hydraulic lifters for my L28. Less maintenance = more time to drive. (As if my car was ready to drive!) Link to comment https://www.classiczcars.com/forums/topic/18544-82-280zxt-p90a-with-solid-lifters/#findComment-152148 Share on other sites More sharing options...
