Posted January 15, 200619 yr comment_152153 Is it possible to install a short shifter kit, like MSA's, with the gearbox in place.Can you do it with the console removed? Link to comment https://www.classiczcars.com/forums/topic/18565-installing-short-shifter/ Share on other sites More sharing options...
January 15, 200619 yr comment_152154 Assuming you can get to the contact point of the gearshift lever (it is a Datsun tranny?). I installed the MSA one with just the center console removed. The hardest part was getting the leverage to slip the rubber cover over the base of the lever where it mounts to the transmission, due to the narrow hole in the floor, but the rest of it was pretty easy.Well worth the effort! The short shifter requires a little more effort (the leverage is less favorable), but its utility is well worth it.Chris Link to comment https://www.classiczcars.com/forums/topic/18565-installing-short-shifter/#findComment-152154 Share on other sites More sharing options...
January 15, 200619 yr Author comment_152155 It has the original 4-speed gearbox. Is it easier to slip the rubber cover over the base from beneath when the car is on jack stands? Link to comment https://www.classiczcars.com/forums/topic/18565-installing-short-shifter/#findComment-152155 Share on other sites More sharing options...
January 15, 200619 yr comment_152165 Just installed the MSA kit last weekend, the boot is the toughest part, but very doable by just removing the console. Link to comment https://www.classiczcars.com/forums/topic/18565-installing-short-shifter/#findComment-152165 Share on other sites More sharing options...
January 16, 200619 yr comment_152211 The boot as all said before is yoru nemesis. Take care and time and all will come to you, easily done with the console removed. Just take your time so you dont lose anything, and curse yourself when you have to crawl under the car. Link to comment https://www.classiczcars.com/forums/topic/18565-installing-short-shifter/#findComment-152211 Share on other sites More sharing options...
January 16, 200619 yr Author comment_152220 The Short shift kit sold by MSA is the best way to go, or is it the only kit on the market? Link to comment https://www.classiczcars.com/forums/topic/18565-installing-short-shifter/#findComment-152220 Share on other sites More sharing options...
March 15, 200717 yr Author comment_202406 Is there an other good resource for a short throw shift kit?Thanks Link to comment https://www.classiczcars.com/forums/topic/18565-installing-short-shifter/#findComment-202406 Share on other sites More sharing options...
