Assuming you can get to the contact point of the gearshift lever (it is a Datsun tranny?). I installed the MSA one with just the center console removed. The hardest part was getting the leverage to slip the rubber cover over the base of the lever where it mounts to the transmission, due to the narrow hole in the floor, but the rest of it was pretty easy.
Well worth the effort! The short shifter requires a little more effort (the leverage is less favorable), but its utility is well worth it.
Chris
The boot as all said before is yoru nemesis. Take care and time and all will come to you, easily done with the console removed. Just take your time so you dont lose anything, and curse yourself when you have to crawl under the car.
  • 1 year later...
