Posted January 16, 200619 yr comment_152219 yeah...finally got the old 2+2 running again with the SDS system, and Sporks (zcar.com) intake manifold. and?theres nothing like it. Eddie Radatz from E. Radatz motorsports drove it...said its on of the strongest NA L28's hes ever seen...the thing is INCREDIBLE. from 2K all the way to 7K it just PULLS...timings set to 35degrees non vaccum adavanced, valves adjusted, and cam timing advanced a little...the engine is incredible. its still running a little rich, so i need to go dyno tune it a lot to get the right power curve.rest assured, i will be at this years SEZ with the car...be on the lookout.. i dont have any updated pictures, only a few which ill upload now...if you are looking for an expensive mod to literally knock like 2 seconds off your 1/4 mile time, a custom intake manifold and fuel managment is where its at. i still cant believe the difference in power this thing makes....im going to go sit in it now :knockedou**im not even going to post the cars ive whooped in it since i got her running :devious: :devious: Link to comment https://www.classiczcars.com/forums/topic/18573-lets-just-say-custom-efi-is-the-way-to-go/ Share on other sites More sharing options...
January 16, 200619 yr comment_152224 Isn't it great when an investment pays off, it kinda takes the sting out of the wallet. Congrats and keep us posted, EFI is the way to go if it can be done. Link to comment https://www.classiczcars.com/forums/topic/18573-lets-just-say-custom-efi-is-the-way-to-go/#findComment-152224 Share on other sites More sharing options...
January 19, 200619 yr comment_152645 Welcome to the programmable injection clubindividual throttle body Injection is an excellent performance modification (been running throttle bodies with programmable mapping for a year now:sleep: ) but misunderstood by many.running a sub 14 second 1/4 mileIf that time is only a guess then thats hardly empirical evidence, however if it is based on a run then it would be good if you had a copy of the timing slip, as a sub 14 time would put you in line for the worlds quickest NA 2+2, bearing in mind that a Subaru Impreza turbo with 270 Hp only runs mid 13's and the legendary GTR Skyline out of the box runs 13.4 its important just how "sub 14" you are :cheeky: Link to comment https://www.classiczcars.com/forums/topic/18573-lets-just-say-custom-efi-is-the-way-to-go/#findComment-152645 Share on other sites More sharing options...
January 20, 200619 yr comment_152719 you didn't get the coil packs with SDS? Link to comment https://www.classiczcars.com/forums/topic/18573-lets-just-say-custom-efi-is-the-way-to-go/#findComment-152719 Share on other sites More sharing options...
January 25, 200619 yr Author comment_153387 nah, didnt get coil packs :-( too expensivesteve, people couldnt believe a 2+2 ran a 15.0 1/4 mile, but everone at the SEZ saw the car run, and was amazed. since then, ive raised the compression from 8.4:1 to 10.1:1, which will make a difference, ive added SDS, fuel managment, a custom intake manifold, coated headers, MSD ignition system, and most importantly, learned a little better how to drive the 1/4 mile.ive told people once, and im tired of saying it: i have a freakin fast 2+2...nobody wants to believe it though, but the members here that attended the SEZ meet saw my car in action, and like i said, couldnt believe how fast she is.i wouldnt say worlds fastest 2+2, im sure a stroked engine would be a lot faster :-)all i know, is that i can say i have one of the fastest 2+2's on this board, or anyother. why? cause nobody takes time to restore 2+2's!!!! :-) Link to comment https://www.classiczcars.com/forums/topic/18573-lets-just-say-custom-efi-is-the-way-to-go/#findComment-153387 Share on other sites More sharing options...
January 25, 200619 yr comment_153388 I like 2+2's. Yours looks beautiful.-Ben Link to comment https://www.classiczcars.com/forums/topic/18573-lets-just-say-custom-efi-is-the-way-to-go/#findComment-153388 Share on other sites More sharing options...
January 25, 200619 yr Author comment_153414 thanks V12....but you know most people dont like them, much less take the time to fully restore them, or even hotrod the engine out and try to make it fast. 1fastZ on zcar.com said his car total weighed 2900lbs with him in the car. well, my 2+2 weighed less than that on the scales, but the only thing from the car i was missing was the carpet and padding, and i doubt that weighs 150lbs...1fastz's car is a coupe...i did a lot of weight reduction, took everything out i didnt need from under the dash, such as AC and other things..engine compartment stuff is removed...under fender covers are gone, all the stock sound insulation is gone....no bumpers or bumper mounts....theres just a lot of weight reduction. the 2+2 after all this isnt an "overweight pig" Link to comment https://www.classiczcars.com/forums/topic/18573-lets-just-say-custom-efi-is-the-way-to-go/#findComment-153414 Share on other sites More sharing options...
January 26, 200619 yr comment_153483 ...under fender covers are goneI have not seen a 240z/260z with under fender covers - is this a US market thing only? (note I did not state 280z as we never got those here) I have also seen a number of Fairlady Z (aka 200z or S30/S31) again no under fender covers.....hmm will check the part catalog I have RHD export models.....looking....no pic or partnumber for a under fender cover in the 240z 260z 2 seater or 260z 2+2 body sections. Link to comment https://www.classiczcars.com/forums/topic/18573-lets-just-say-custom-efi-is-the-way-to-go/#findComment-153483 Share on other sites More sharing options...
January 26, 200619 yr Author comment_153499 wheel well covers..i think its a total of 6 pieces of large plastic that bolts up underneath the front fenders...above the wheel...useless in my opnion. just more weight :-) Link to comment https://www.classiczcars.com/forums/topic/18573-lets-just-say-custom-efi-is-the-way-to-go/#findComment-153499 Share on other sites More sharing options...
