Want to verify something as I prepare for the auto to manual tranny swap. Here's the question - the car, clutch and transmission are '71 vintage, the engine is '83 and the flywheel will be something like a '77 or so. I see numerous flywheel bolt choices, can I assume I need bolts to match the flywheel ('77 or so)? Or the engine ('83)? To me, matching the flywheel seems most logical.
https://www.classiczcars.com/forums/topic/18605-what-flywheel-bolts/
The bolts will be the same length. I just used a 77 flywheel and an '82 tranny, on a 83 engine(it had an auto tranny)-just be sure to remove the spacer, and add the bushing...
WIll
WIll
So which bolts did you use, Will? The ones from the '83 flex plate?
