on my 71 240, the previous owner put in a L28, and a Mallory Promaster coil. how should I hook up the wires to make the tach work?
this is how i have it hooked up now;the car runs, but the tach doesn't work:
------I
n...-.I====B==to distributor==
.......I
.coil.I
.......I
p..+.I====BW==to wiring harness==
.......I
------I
1=Covered BW to harness
2=GW to harness
I---1--------2---I
I......................I
I...Resistor......I
i used a multimeter to check for continuity, and found that the covered black and white wire goes to the tach, and the uncovered one goes to the ignition switch. however, if i connect the wires like the wiring diagram says (switching the two BW wires), i get no spark @ the coil. what's going on here??
https://www.classiczcars.com/forums/topic/1862-tach/
